A Failure Adapted, Load-balanced Distributed Routing for Wireless Ad-hoc Sensor Networks
this paper proposes a distributed routing protocol for ad hoc sensor networks which uses Fuzzy Logic. Each sensor uses a Fuzzy decision making process to find the best Cluster Head. Simulation shows that this protocol is able to dynamically adapt to sensors' mobility and failure. By a new load balancing method, it provides also stable clusters and so a cluster head have greater lifetime, which results minimum message exchange and so minimum energy consumption.
A_Failure_Adapted_Load-balanced_Distributed_Routing_for_Wireless_Ad-hoc_Sensor_Networks.pdf (347.69 Ko)
Télécharger le fichier
