Task Delegation Based Access Control Models for Workflow Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
e-Government organisations are facilitated and conducted using workflow management systems. Role-based access control (RBAC) is recognised as an efficient access control model for large organisations. The application of RBAC in workflow systems cannot, however, grant permissions to users dynamically while business processes are being executed. We currently observe a move away from predefined strict workflow modelling towards approaches supporting flexibility on the organisational level. One specific approach is that of task delegation. Task delegation is a mechanism that supports organisational flexibility, and ensures delegation of authority in access control systems. In this paper, we propose a Task-oriented Access Control (TAC) model based on RBAC to address these requirements. We aim to reason about task from organisational perspectives and resources perspectives to analyse and specify authorisation constraints. Moreover, we present a fine grained access control protocol to support delegation based on the TAC model.
gaaloul_i3e.pdf (926.83 Ko) Télécharger le fichier
inria-00431498 , version 1 (12-11-2009)
inria-00431498 , version 2 (14-11-2009)
  • HAL Id : inria-00431498 , version 2
Khaled Gaaloul, François Charoy. Task Delegation Based Access Control Models for Workflow Systems. The 9th IFIP Conference on e-Business, e-Services, and e-Society, I3E 2009, Sep 2009, Nancy, France. ⟨inria-00431498v2⟩
102 Consultations
689 Téléchargements
