Cosmological Simulations on a Grid of Computers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
The work presented in this paper aims at restricting the input parameter values of the semi-analytical model used in Galics and MoMaF, so as to derive which parameters influence the most the results, e.g., star forma- tion, feedback and halo recycling efficiencies, etc. Our approach is to proceed empirically: we run lots of simulations and derive the correct ranges of values. The computation time needed is so large, that we need to run on a grid of com- puters. Hence, we model Galics and MoMaF execution time and output files size, and run the simulation using a grid middleware: Diet. All the complexity of accessing resources, scheduling simulations and managing data is harnessed by Diet and hidden behind a web portal accessible to the users.
RR-7093.pdf (606.82 Ko) Télécharger le fichier
inria-00431637 , version 1 (12-11-2009)
  • HAL Id : inria-00431637 , version 1
Benjamin Depardon, Eddy Caron, Frédéric Desprez, H.M. Courtois, Jeremy Blaizot. Cosmological Simulations on a Grid of Computers. [Research Report] RR-7093, Inria. 2009, pp.15. ⟨inria-00431637⟩
323 Consultations
197 Téléchargements
