A new protein-protein docking scoring function based on interface residue properties. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bioinformatics Année : 2007
MOTIVATION: Protein-protein complexes are known to play key roles in many cellular processes. However, they are often not accessible to experimental study because of their low stability and difficulty to produce the proteins and assemble them in native conformation. Thus, docking algorithms have been developed to provide an in silico approach of the problem. A protein-protein docking procedure traditionally consists of two successive tasks: a search algorithm generates a large number of candidate solutions, and then a scoring function is used to rank them. RESULTS: To address the second step, we developed a scoring function based on a Voronoï tessellation of the protein three-dimensional structure. We showed that the Voronoï representation may be used to describe in a simplified but useful manner, the geometric and physico-chemical complementarities of two molecular surfaces. We measured a set of parameters on native protein-protein complexes and on decoys, and used them as attributes in several statistical learning procedures: a logistic function, Support Vector Machines (SVM), and a genetic algorithm. For the later, we used ROGER, a genetic algorithm designed to optimize the area under the receiver operating characteristics curve. To further test the scores derived with ROGER, we ranked models generated by two different docking algorithms on targets of a blind prediction experiment, improving in almost all cases the rank of native-like solutions. AVAILABILITY: http://genomics.eu.org/spip/-Bioinformatics-tools-
inria-00431697 , version 1 (12-11-2009)
Julie Bernauer, Jérôme Azé, Joël Janin, Anne Poupon. A new protein-protein docking scoring function based on interface residue properties.. Bioinformatics, 2007, 23 (5), pp.555-62. ⟨10.1093/bioinformatics/btl654⟩. ⟨inria-00431697⟩
92 Consultations
0 Téléchargements
