New interface
Journal articles
Material Space Texturing
Nicolas Ray 1 Bruno Lévy 1 Wang Huamin 2 Turk Greg 2 Bruno Vallet 1
1 ALICE - Geometry and Lighting
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : Many objects have patterns that vary in appearance at different surface locations.We say that these are differences in materials, and we present a material-space approach for interactively designing such textures. At the heart of our approach is a new method to pre-calculate and use a 3D texture tile that is periodic in the spatial dimensions (s; t) and that also has a material axis along which the materials change smoothly. Given two textures and their feature masks, our algorithm produces such a tile in two steps. The first step resolves the features morphing by a level set advection approach, improved to ensure convergence. The second step performs the texture synthesis at each slice in material-space, constrained by the morphed feature masks. With such tiles, our system lets a user interactively place and edit textures on a surface, and in particular, allows the user to specify which material appears at given positions on the object. Additional operations include changing the scale and orientation of the texture. We support these operations by using a global surface parameterization that is closely related to quad re-meshing. Re-parameterization is performed on-the-fly whenever the user's constraints are modified.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00432402
Contributor : Nicolas Ray Connect in order to contact the contributor
Submitted on : Monday, November 16, 2009 - 2:20:17 PM
Last modification on : Saturday, November 19, 2022 - 3:59:05 AM
Links full text
Identifiers
Citation
Nicolas Ray, Bruno Lévy, Wang Huamin, Turk Greg, Bruno Vallet. Material Space Texturing. Computer Graphics Forum, 2009, 28 (6), pp.1659-1669. ⟨10.1111/j.1467-8659.2009.01423.x⟩. ⟨inria-00432402⟩
Share
Metrics
Record views
103
