Correspondence and translation for heterogeneous data, Proceedings of the International Conference on DataBase Theory, pp.351-363, 1997. ,
A comparison of fast blocking methods for record linkage, Proceedings of ACM SIGKDD'03 Workshop on Data Cleaning Record Linkage and Object Consolidation, pp.25-27, 2003. ,
Entity Resolution in Graphs Mining Graph Data, 2006. ,
Schema Matching Using Duplicates, 21st International Conference on Data Engineering (ICDE'05), pp.69-80, 2005. ,
DOI : 10.1109/ICDE.2005.126
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.61.323
XQuery 1.0 : An XML Query Language, W3C Recommendation, 2007. ,
Symbolic Logic and Mechanical Theorem Proving, 1997. ,
Your mediators need data conversion !, Proceedings of SIGMOD'98, pp.177-188, 1998. ,
DOI : 10.1145/276305.276321
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.43.3537
Data integration using similarity joins and a word-based information representation language, ACM Transactions on Information Systems, vol.18, issue.3, pp.288-321, 2000. ,
DOI : 10.1145/352595.352598
A Comparison of String Distance Metrics for Name-Matching Tasks, Proceedings of the Workshop on Information Integration on the Web, pp.73-78, 2003. ,
Entity matching in heterogeneous databases: a distance-based decision model, Proceedings of the Thirty-First Hawaii International Conference on System Sciences, pp.305-313, 1998. ,
DOI : 10.1109/HICSS.1998.649225
A Probabilistic Decision Model for Entity Matching in Heterogeneous Databases, Management Science, vol.44, issue.10, pp.1379-1395, 1998. ,
DOI : 10.1287/mnsc.44.10.1379
Reference reconciliation in complex information spaces, Proceedings of the 2005 ACM SIGMOD international conference on Management of data , SIGMOD '05, pp.85-96, 2005. ,
DOI : 10.1145/1066157.1066168
A Theory for Record Linkage, Journal of the American Statistical Association, vol.63, issue.328, pp.1183-1210, 1969. ,
DOI : 10.1126/science.130.3381.954
Building problem solvers, 1993. ,
Matrix computations, 1996. ,
RDF Semantics, from http, 2004. ,
Unit Refutations and Horn Sets, Journal of the ACM, vol.21, issue.4, pp.590-605, 1974. ,
DOI : 10.1145/321850.321857
Mediating RDF/S Queries to relational and XML Sources, International Journal on Semantic Web & Information Systems, vol.2, issue.4, pp.78-91, 2006. ,
The Resource Description Framework (RDF) and its Vocabulary Description Language RDFS, Handbook on Ontologies, pp.51-66, 2004. ,
DOI : 10.1007/978-3-540-24750-0_3
OWL: Web Ontology Language Overview. W3C recommendation, from http, 2004. ,
Record linkage: making maximum use of the discriminating power of identifying information, Communications of the ACM, vol.5, issue.11, pp.563-566, 1962. ,
DOI : 10.1145/368996.369026
Automatic Linkage of Vital Records: Computers can be used to extract "follow-up" statistics of families from files of routine records, Science, vol.130, issue.3381, pp.954-959, 1959. ,
Multi-relational record linkage, Proceedings of the ACM SIGKDD Workshop on Multi-Relational Data Mining, pp.31-48, 2004. ,
Translating Web Data, Proceedings of the VLDB Conference, pp.598-609, 2002. ,
DOI : 10.1016/B978-155860869-6/50059-7
Construction automatique d'adaptateurs guid??e par une ontologie pour l'int??gration de sources et de donn??es XML, Techniques et sciences informatiques, vol.28, issue.2, 2009. ,
DOI : 10.3166/tsi.28.199-228
URL : https://hal.inria.fr/inria-00432426/document
A Machine-Oriented Logic Based on the Resolution Principle, Journal of Association for Computing Machinery, vol.12, issue.1, pp.23-41, 1965. ,
DOI : 10.1007/978-3-642-81952-0_26
Picsel and Xyleme: Two illustrative Information Integration Agents Intelligent Information Agents Research and development in Europe: An AgentLink Perspective, LNCS State of the Art Surveys, pp.50-78, 2003. ,
Construction de médiateurs pour intégrer des sources d'information multiples et hétérogènes : le projet PICSEL, pp.9-59, 2002. ,
Combining a Logical and a Numerical Method for Data Reconciliation, Journal of Data Semantics LNCS, vol.25, issue.10, pp.66-94, 2009. ,
L2R: A Logical Method for Reference Reconciliation, Proceedings of the Twenty-Second AAAI Conference on Artificial Intelligence, pp.329-334, 2007. ,
Querying XML sources using an ontologybased mediator, Proceedings of Confederated International Conferences Doa, pp.429-448, 2002. ,
Data Quality: Concepts, Methodologies and Techniques (Data- Centric Systems And applications), 2006. ,
Swoosh: a generic approach to entity resolution, The VLDB Journal, vol.26, issue.8, 2009. ,
DOI : 10.1007/s00778-008-0098-x
Adaptive name matching in information integration, IEEE Intelligent Systems, vol.18, issue.5, pp.16-23, 2003. ,
DOI : 10.1109/MIS.2003.1234765
Representing and Querying Data Transformations, Proceedings of International Conference on Data Engineering, pp.81-92, 2005. ,
The ICS-FORTH Semantic Web Integration Middleware (SWIM), IEEE Data Engineering Bulletine, vol.26, issue.4, pp.11-18, 2003. ,
Integration of Heterogeneous Databases Without Common Domains Using Queries Based on Textual Similarity, Proceedings of the SIGMOD Conference, pp.201-212, 1998. ,
Profile-based object matching for information integration, IEEE Intelligent Systems, vol.18, issue.5, pp.54-59, 2003. ,
DOI : 10.1109/MIS.2003.1234770
Real-world Data is Dirty: Data Cleansing and The Merge/Purge Problem, Data Mining and Knowledge Discovery, vol.2, issue.1, pp.9-37, 1998. ,
DOI : 10.1023/A:1009761603038
Data Quality and Record Linkage Techniques, 2007. ,
Exploiting relationships for domain-independent data cleaning, 2005. ,
DOI : 10.1137/1.9781611972757.24
Interpreting XML via an RDF Schema, Proceedings of the International Workshop on Database and Expert Systems Applications, pp.889-893, 2002. ,
Toolkits for Generating Wrappers ? A Survey of Software Toolkits for Automated Data Extraction from Websites, International Conference NetObjectDays, pp.184-198, 2002. ,
A brief survey of web data extraction tools, ACM SIGMOD Record, vol.31, issue.2, pp.84-93, 2002. ,
DOI : 10.1145/565117.565137
Data integration, Proceedings of the twenty-first ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '02, pp.233-246, 2002. ,
DOI : 10.1145/543613.543644
XWRAP: an XML-enabled wrapper construction system for Web information sources, Proceedings of 16th International Conference on Data Engineering (Cat. No.00CB37073), pp.611-621, 2000. ,
DOI : 10.1109/ICDE.2000.839475
Query Translation between RDF and XML: A Case Study in the Educational Domain, Proceedings of the Workshop of the Interoperability of Web-Based Educational Systems, 2005. ,
The Clio project, Proceedings of the ACM SIGMOD International Conference on Management of Data, pp.78-83, 2001. ,
DOI : 10.1145/373626.373713
Using Schema matching to Simplify Heterogeneous Data Translation, Proceedings of the International Conference on VLDB, pp.122-133, 1998. ,
An Efficient Domain-Independent Algorithm for Detecting Approximately Duplicate Database Records, ACM SIGMOD Workshop on Research Issues on Data Mining and Knowledge Discovery, pp.23-29, 1997. ,
Reference Fusion and Flexible Querying, Proceedings of the Conference on Ontologies, DataBases, and Applications of Semantics (ODBASE), pp.1541-1549, 2008. ,
DOI : 10.1007/978-3-540-88873-4_42
Data Integration in Data Warehousing, International Journal of Cooperative Information Systems, vol.10, issue.3, pp.237-271, 2001. ,
Representing and Querying Data Transformations, 21st International Conference on Data Engineering (ICDE'05), pp.81-92, 2005. ,
DOI : 10.1109/ICDE.2005.123
A Bayesian decision model for cost optimal record matching, The VLDB Journal The International Journal on Very Large Data Bases, vol.12, issue.1, pp.28-40, 2003. ,
DOI : 10.1007/s00778-002-0072-y
