Viscous Sublayer and Adjacent Wall Region in Turbulent Pipe Flow, Physics of Fluids, vol.10, issue.9, 1967. ,
DOI : 10.1063/1.1762382
The dynamics of coherent structures in the wall region of a turbulent boundary layer, Journal of Fluid Mechanics, vol.15, issue.-1, pp.115-173, 1988. ,
DOI : 10.1146/annurev.fl.13.010181.002325
Low-dimensional control of the circular cylinder wake, Journal of Fluid Mechanics, vol.371, pp.157-178, 1998. ,
DOI : 10.1017/S0022112098002122
Optimal rotary control of the cylinder wake using proper orthogonal decomposition reduced-order model, Physics of Fluids, vol.17, issue.9, p.97101, 2005. ,
DOI : 10.1063/1.2033624
Turbulent inflow conditions for large-eddy simulation based on low-order empirical model, Physics of Fluids, vol.20, issue.7, p.75107, 2008. ,
DOI : 10.1063/1.2957019
URL : https://hal.archives-ouvertes.fr/hal-00384020
Polynomial identification of POD based low-order dynamical system, Journal of Turbulence, vol.3, issue.17, 2006. ,
DOI : 10.1080/14685240600559665
URL : https://hal.archives-ouvertes.fr/hal-00124564
Variational assimilation of pod low-order dynamical systems, Journal of Turbulence, vol.8, issue.9, pp.1-22, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00596160
A proper-orthogonal-decomposition???based model for the wall layer of a turbulent channel flow, Physics of Fluids, vol.21, issue.1, 2009. ,
DOI : 10.1063/1.3068759
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A, vol.109, issue.2, pp.97-110, 1986. ,
DOI : 10.1111/j.1600-0870.1986.tb00459.x
Optimal control of systems governed by PDEs, 1971. ,
Assimilation de données images : application au suivi de courbes et de champs de vitesses, 2007. ,
Anémométrie fil chaudàchaud`chaudà température variable : applicationàapplication`applicationà l'´ etude d'une couche de mélange anisotherme, 2007. ,
Experimental and numerical studies of the flow over a circular cylinder at Reynolds number 3900, Physics of Fluids, vol.20, issue.8, p.85101, 2008. ,
DOI : 10.1063/1.2957018
URL : https://hal.archives-ouvertes.fr/hal-00383669
