HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Short paper: 3-Hand Manipulation of Virtual Objects
Laurent Aguerreche 1 Thierry Duval 1 Anatole Lécuyer 1
1 BUNRAKU - Perception, decision and action of real and virtual humans in virtual environments and impact on real environments
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, ENS Cachan - École normale supérieure - Cachan, Inria Rennes – Bretagne Atlantique
Abstract : In this paper we introduce a new 3D interaction technique called “3-Hand Manipulation”, for multi-user collaborative manipulation of 3D objects. The 3-Hand Manipulation relies on the use of three manipulation points that can be used simultaneously by three different “hands” of two or three users. Interestingly, the three translation motions of the manipulation points can fully determine the resulting 6 degrees of freedom motion of the manipulated object. We describe the implementation of the 3-Hand Manipulation, its graphical representations and an illustration of its use by two or three users on an insertion task in immersive virtual environment. This technique could be used in various applications of collaborative VR such as for virtual prototyping, training simulations, assembly and maintenance simulations.
Document type :
Conference papers
Complete list of metadata
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/inria-00433856
Contributor : Thierry Duval Connect in order to contact the contributor
Submitted on : Friday, November 20, 2009 - 12:47:01 PM
Last modification on : Friday, February 4, 2022 - 3:12:44 AM
Long-term archiving on: : Thursday, June 17, 2010 - 9:08:16 PM
File
ThreeHandManipulation.pdf
Identifiers
  • HAL Id : inria-00433856, version 1
Citation
Laurent Aguerreche, Thierry Duval, Anatole Lécuyer. Short paper: 3-Hand Manipulation of Virtual Objects. JVRC 2009, Eurographics, Dec 2009, Lyon, France. 4 p. ⟨inria-00433856⟩
Share
Metrics
Record views
323
Files downloads
165
