New interface
Reports (Research report)
Program Termination and Worst Time Complexity with Multi-Dimensional Affine Ranking Functions
Christophe Alias 1 Alain Darte 1 Paul Feautrier 1 Laure Gonnord 1 Clément Quinson 1
1 COMPSYS - Compilation and embedded computing systems
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : A standard method for proving the termination of a flowchart program is to exhibit a ranking function, i.e., a function from the program states to a well-founded set, which strictly decreases at each program step. Our main contribution is to give an efficient algorithm for the automatic generation of multi-dimensional affine nonnegative ranking functions, a restricted class of ranking functions that can be handled with linear programming techniques. Our algorithm is based on the combination of the generation of invariants (a technique from abstract interpretation) and on an adaptation of multi-dimensional affine scheduling (a technique from automatic parallelization). We also prove the completeness of our technique with respect to its input and the class of rankings we consider. Finally, as a byproduct, by computing the cardinal of the range of the ranking function, we obtain an upper bound for the computational complexity of the source program, which does not depend on restrictions on the shape of loops or on program structure. This estimate is a polynomial, which means that we can handle programs with more than linear complexity. The method is tested on a large collection of test cases from the literature. We also point out future improvements to handle larger programs.
Document type :
Complete list of metadata
Cited literature [41 references]  Display  Hide  Download
https://hal.inria.fr/inria-00434037
Contributor : Christophe Alias Connect in order to contact the contributor
Submitted on : Friday, November 20, 2009 - 3:43:54 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:47 AM
Long-term archiving on: : Thursday, June 17, 2010 - 6:33:24 PM
File
RR-7037.pdf
Identifiers
  • HAL Id : inria-00434037, version 1
Citation
Christophe Alias, Alain Darte, Paul Feautrier, Laure Gonnord, Clément Quinson. Program Termination and Worst Time Complexity with Multi-Dimensional Affine Ranking Functions. [Research Report] 2009, pp.31. ⟨inria-00434037⟩
Share
Metrics
Record views
234
Files downloads
121
