Wand Based Calibration of 3D Kinematic System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IET Computer Vision Année : 2009
This study proposes a method to calibrate 3D kinematic systems. The authors briefly address typical wand-based calibration, that is, calibration using a rigid bar, both from the computational point of view and the procedural perspective, and then they define their alternative way of calibration. The proposed method takes advantage of a feature of the presently used calibration tools, that is, the orthogonality of calibration wands. The usual two steps in wand calibration are reduced to a single one. In addition, the authors propose an alternative for how to enforce a typically available geometric constraint, that is, the known wand length, during the parameter optimisation procedure (the well-known bundle adjustment). The obtained 3D reconstruction accuracy has proven to be comparable with results of commercial 3D kinematic systems. The relative simplicity of the proposed method offers potential for an implementation by a large number of researchers.
Fichier non déposé
inria-00434345 , version 1 (22-11-2009)
Tomislav Pribanić, Peter Sturm, Stanislav Peharec. Wand Based Calibration of 3D Kinematic System. IET Computer Vision, 2009, 3 (3), pp.124-129. ⟨10.1049/iet-cvi.2009.0004⟩. ⟨inria-00434345⟩
294 Consultations
0 Téléchargements
