Some numerical aspects of the conservative PSM scheme in a 4D drift-kinetic code. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
The purpose of this work is simulation of magnetised plasmas in the ITER project framework. In this context, kinetic Vlasov-Poisson like models are used to simulate core turbulence in the tokamak in a toroidal geometry. This leads to heavy simulations because a 6D dimensional problem has to be solved, even if reduced to a 5D in so called gyrokinetic models. Accurate schemes, parallel algorithms need to be designed to bear these simulations. This paper describes the numerical studies to improve robustness of the conservative PSM scheme in the context of its development in the GYSELA code. In this paper, we only consider the 4D drift-kinetic model which is the backbone of the 5D gyrokinetic models and relevant to build a robust and accurate numerical method.
article_numaspects_CPC.pdf (1.19 Mo) Télécharger le fichier
inria-00435203 , version 1 (26-11-2009)
inria-00435203 , version 2 (09-03-2013)
  • HAL Id : inria-00435203 , version 2
  • ARXIV : 1303.2238
Jean-Philippe Braeunig, Nicolas Crouseilles, Virginie Grandgirard, Guillaume Latu, Michel Mehrenberger, et al.. Some numerical aspects of the conservative PSM scheme in a 4D drift-kinetic code.. 2011. ⟨inria-00435203v2⟩
665 Consultations
242 Téléchargements
