Independent Component Analysis Segmentation Algorithm, 8th International Conference on Document Analysis and Recognition, pp.680-684, 2005. ,
Text line and word segmentation of handwritten documents, 11th International Conference on Frontiers in Handwriting Recognition, pp.599-603, 2008. ,
DOI : 10.1016/j.patcog.2008.12.016
Separation of touching and overlapping words in adjacent lines of handwritten text, Proceedings Eighth International Workshop on Frontiers in Handwriting Recognition, pp.496-501, 2002. ,
DOI : 10.1109/IWFHR.2002.1030959
Survey on Independent Component Analysis, 1999. ,
Using Hidden Markov Models as a Tool for Handwritten Text Line Segmentation, Ninth International Conference on Document Analysis and Recognition (ICDAR 2007), pp.8-12, 2007. ,
DOI : 10.1109/ICDAR.2007.4378666
Text Line Segmentation of Historical Arabic Documents, Ninth International Conference on Document Analysis and Recognition (ICDAR 2007), pp.138-142, 2007. ,
DOI : 10.1109/ICDAR.2007.4378691
Segmentation of Curled Text Lines using Active Contours, Proceedings of Eight IAPR Workshop on Document Analysis Systems, pp.270-277, 2008. ,
Line Separation for Complex Document Images Using Fuzzy Run length, Proc. Of the Int. Workshop on Document Image Analysis for Libraries, 2004. ,
Multi-oriented Text Line Extraction from Handwritten Arabic Documents, 2008 The Eighth IAPR International Workshop on Document Analysis Systems, pp.339-346, 2008. ,
DOI : 10.1109/DAS.2008.14
URL : https://hal.archives-ouvertes.fr/inria-00347225
Thinning methodologies-a comprehensive survey, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.9, pp.869-885, 1992. ,
DOI : 10.1109/34.161346
Stepwise recovery of arc segmentation in complex line environments, International Journal on Document Analysis and Recognition, vol.1, issue.1, pp.62-71, 1998. ,
Generalizing the Hough transform to detect arbitrary shapes, Pattern Recognition, vol.13, issue.2, pp.111-122, 1981. ,
DOI : 10.1016/0031-3203(81)90009-1
Segmentation of edges into lines and arcs, Image and Vision Computing, vol.7, issue.2, pp.109-114, 1989. ,
DOI : 10.1016/0262-8856(89)90004-8
