Conference papers
Cohen's Class Distributions for Skew Angle Estimation in Noisy Ancient Arabic Documents
Nazih Ouwayed 1 Abdel Belaïd 1 François Auger 2
1 READ - READ
LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : This paper presents an adaptive method for the skew angle estimation of noisy handwritten Arabic documents using the energy distributions of Cohen's class. The presence of noise in raw document images can create local maxima which disturb the projection histogram analysis. To avoid this drawback, we propose to use Cohen's class distributions on the projection histogram profiles obtained using different projection angles. These distributions reduce the importance of these local maxima and are fitted to the nonstationary nature of these histogram profiles. The orientation of the document is given by the highest maximum. The proposed skew angle detection technique has been evaluated on 864 skewed documents. The results of each distribution are presented at the end of this paper.
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/inria-00435253
Contributor : Abdel Belaid Connect in order to contact the contributor
Submitted on : Tuesday, November 24, 2009 - 8:46:21 AM
Last modification on : Wednesday, April 27, 2022 - 3:56:37 AM
Long-term archiving on: : Thursday, June 17, 2010 - 9:35:56 PM
File
WVD.pdf
Identifiers
Citation
Nazih Ouwayed, Abdel Belaïd, François Auger. Cohen's Class Distributions for Skew Angle Estimation in Noisy Ancient Arabic Documents. Third Workshop on Analytics for Noisy Unstructured Text Data - AND 2009, Jul 2009, Barcelona, Spain. pp.41-46, ⟨10.1145/1568296.1568305⟩. ⟨inria-00435253⟩
Share
Metrics
Record views
275
Files downloads
306
