Templates for the Solution of Linear Systems: Building Blocks for Iterative Methods, 1994. ,
DOI : 10.1137/1.9781611971538
Atomic shared register access by asynchronous hardware (detailed abstract), " in FOCS, IEEE, pp.233-243, 1986. ,
Atomic snapshots of shared memory, Journal of the ACM, vol.40, issue.4, pp.873-890, 1993. ,
DOI : 10.1145/153724.153741
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.39.4013
Time-optimal, space-efficient single-scanner snapshots & multi-scanner snapshots using CAS, Proceedings of the twenty-sixth annual ACM symposium on Principles of distributed computing, PODC '07, pp.33-42, 2007. ,
DOI : 10.1145/1281100.1281108
Iterative computations with ordered read-write locks, Journal of Parallel and Distributed Computing, p.6685, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00330024
Token-Based Read/Write-Locks for Distributed Mutual Exclusion, Euro-Par '00: Proceedings from the 6th International Euro-Par Conference on Parallel Processing, pp.1185-1195, 2000. ,
DOI : 10.1007/3-540-44520-X_167
Closing the complexity gap between fcfs mutual exclusion and mutual exclusion, DISC, ser. Lecture Notes in Computer Science, pp.93-108, 2008. ,
Out-of-core wavefront computations with reduced synchronization Distributed and network-based Processing, 16th Euromicro International Conference on Parallel, pp.293-300, 2008. ,
