Extraction and simplification of iso-surfaces in tandem, SGP '05: Proceedings of the third Eurographics symposium on Geometry processing, pp.139-148, 2005. ,
Marching cubes: A high-resolution 3D surface construction algorithm, Proceedings of the 14th annual conference on Computer graphics and interactive techniques, pp.163-169, 1987. ,
Topological considerations in isosurface generation, ACM Transactions on Graphics, vol.13, issue.4, pp.337-375, 1994. ,
DOI : 10.1145/195826.195828
Octrees for faster isosurface generation, ACM Transactions on Graphics, vol.11, issue.3, pp.201-227, 1992. ,
DOI : 10.1145/130881.130882
A near optimal isosurface extraction algorithm using the span space, IEEE Transactions on Visualization and Computer Graphics, vol.2, issue.1, pp.73-84, 1996. ,
DOI : 10.1109/2945.489388
A load-balanced parallel implementation of the marching-cubes algorithm, 1995. ,
A fast parallel marching-cubes implementation on the Fujitsu AP1000, 1992. ,
Octree-based decimation of marching cubes surfaces, Proceedings of Seventh Annual IEEE Visualization '96, pp.335-342, 1996. ,
DOI : 10.1109/VISUAL.1996.568127
Out-of-core simplification of large polygonal models, Proceedings of the 27th annual conference on Computer graphics and interactive techniques , SIGGRAPH '00, pp.259-262, 2000. ,
DOI : 10.1145/344779.344912
External memory management and simplification of huge meshes, IEEE Transactions on Visualization and Computer Graphics, vol.9, issue.4, pp.525-537, 2003. ,
DOI : 10.1109/TVCG.2003.1260746
A stream algorithm for the decimation of massive meshes, Graphics Interface 2003 Proceedings, pp.185-192, 2003. ,
Surface simplification using quadric error metrics, Proceedings of the 24th annual conference on Computer graphics and interactive techniques , SIGGRAPH '97, pp.209-216, 1997. ,
DOI : 10.1145/258734.258849
Complex Volumic Seismic Interpretation by New Geobodies Extraction Strategy, 69th EAGE Conference and Exhibition incorporating SPE EUROPEC 2007, 2007. ,
DOI : 10.3997/2214-4609.201401472
Adaptive generation of surfaces in volume data, The Visual Computer, vol.2, issue.4, 1993. ,
DOI : 10.1007/BF01901723
Components extracted on a dataset of size 1626×7028×2000 (see figure 14) and filtered according to their volumes ,
