Efficient and robust reconstruction of botanical branching structure from laser scanned points - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper presents a reconstruction pipeline for recovering branching structure of trees from laser scanned data points. The process is made up of two main blocks: segmentation and reconstruction. Based on a variational k-means clustering algorithm, cylindrical components and ramified regions of data points are identified and located. An adjacency graph is then built from neighborhood information of components. Simple heuristics allow us to extract a skeleton structure and identify branches from the graph. Finally, a B-spline model is computed to give a compact and accurate reconstruction of the branching system.
main.pdf (1.86 Mo) Télécharger le fichier
Format : Figure, Image
inria-00436480 , version 1 (26-11-2009)
  • HAL Id : inria-00436480 , version 1
Dong-Ming Yan, Julien Wintz, Bernard Mourrain, Wenping Wang, Frédéric Boudon, et al.. Efficient and robust reconstruction of botanical branching structure from laser scanned points. CAD/Graphics 2009, Aug 2009, Yellow Mountain City, China. pp.572-575. ⟨inria-00436480⟩
498 Consultations
909 Téléchargements
