Coupled Simulation-Measurements Platform for the Evaluation of Frequency-Reuse in the 2.45 GHz ISM band for Multi-mode Nodes with Multiple Antennas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue EURASIP Journal on Wireless Communications and Networking Année : 2009
In this paper we address the problem of efficiently evaluate performance of concurrent radio links on overlapped channels. In complex network topologies with various standards and frequency channels, simulating a realistic PHY layer communication is a key point. The presented coupled simulation-measurement platform offers a very promising way of rapidly modelling and validating effective performance of multi-mode, multi-channel and multi-antenna radio nodes. An accurate of radio channel is performed and then realistic performance with or without antenna processing is shown, verifying theoretical performance. Finally, available performance of concurrent communications on overlapped channels is exposed, showing that this approach is viable to enhance network capacity.
JWCN302151v2.pdf (810.9 Ko) Télécharger le fichier
inria-00436622 , version 1 (27-11-2009)
  • HAL Id : inria-00436622 , version 1
Guillaume Villemaud, Pierre-François Morlat, Jacques Verdier, Jean-Marie Gorce, Marylin Arndt. Coupled Simulation-Measurements Platform for the Evaluation of Frequency-Reuse in the 2.45 GHz ISM band for Multi-mode Nodes with Multiple Antennas. EURASIP Journal on Wireless Communications and Networking, 2009. ⟨inria-00436622⟩
208 Consultations
180 Téléchargements
