Signal Path Optimization in Software-Defined Radio SystemsCombined Effects of RF Impairments in the Future IEEE 802.11n WLAN Systems, IEEE Trans. On Mic. Th. And Tech. IEEE Vehicular Technology Conference, vol.533, issue.2, 2005. ,
Toward Multistandard Mobile Terminals ? Fully Integrated Receivers Requirements and Architectures SMI adaptive antenna arrays for weak interfering signals Application of antenna arrays to mobile communications, part II: beam forming and direction of arrival considerations, Part 11: Wireless LAN Medium Access Control (MAC) and Physical Layer (PHY) Specifications: Further Higher Data Rate Extension in the 2.4 GHz Band [9] Channel Models for HIPERLAN/2 in different indoor Scenarios. ETSI EP BRAN 3ER1085B, pp.1237-1242, 1986. ,
Joint compensation of IQ imbalance, frequency offset and phase noise in OFDM receivers, European Transactions on Telecommunications, vol.15, issue.3, 2004. ,
DOI : 10.1002/ett.974
Influence of RF oscillators on an OFDM signal, Proc. IEEE Seventh International Symposium on Spread Spectrum Techniques and Applications Proc. 41 st Annual Frequency Control Symposium Phase locking in high performance systems : From Devices to Architectures " publisher J, pp.592-603133, 1987. ,
DOI : 10.1109/30.468090
