Stereo tracking and servoing for space applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advanced Robotics Année : 2009
This paper proposes a real-time, robust and efficient 3D model-based tracking algorithm for visual servoing. A virtual visual servoing approach is used for 3D tracking. This method is similar to more classical non-linear pose computation techniques. Robustness is obtained by integrating an M-estimator into the virtual visual control law via an iteratively re-weighted least squares implementation. The presented approach is also extended to the use of multiple cameras. Results show the method to be robust to occlusion, changes in illumination and miss-tracking.
2009_ar_dionnet.pdf (1.13 Mo) Télécharger le fichier
inria-00436743 , version 1 (27-11-2009)
  • HAL Id : inria-00436743 , version 1
F. Dionnet, Eric Marchand. Stereo tracking and servoing for space applications. Advanced Robotics, 2009, 23 (5), pp.579-599. ⟨inria-00436743⟩
202 Consultations
152 Téléchargements
