Conference papers
A temptative to reach a visual singular configuration using Halley's method
M. Marey 1 François Chaumette 1
1 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : Image-based visual servoing has been found to give satisfactory accurate and robust results. However, sin- gularity and local minima may appear causing stability and convergence problems. In this paper, we present new control schemes based on Halley's method as a temptative to obtain a robust system even when the desired configuration is singular. The new control scheme use the first and the second order derivatives of the error to be regulated to zero. Hessian matrices of an image point are thus determined to be used in the control schemes. Preliminary experimental results obtained on a 6 dof eye-in-hand system shows that a more accurate positioning can be obtained compared with classical methods.
Document type :
Conference papers
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/inria-00436756
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Friday, November 27, 2009 - 4:53:18 PM
Last modification on : Thursday, January 20, 2022 - 4:20:27 PM
Long-term archiving on: : Thursday, June 17, 2010 - 10:33:59 PM
File
2009_icra_marey.pdf
Identifiers
  • HAL Id : inria-00436756, version 1
Citation
M. Marey, François Chaumette. A temptative to reach a visual singular configuration using Halley's method. IEEE Int. Conf. on Robotics and Automation, ICRA'09, 2009, Kobe, Japan, Japan. pp.1122-1127. ⟨inria-00436756⟩
Share
Metrics
Record views
161
Files downloads
134
