Efficiency and mutation strength adaptation of the (mu/mui,lambda)-es in a noisy environment, Parallel Problem Solving from Nature, pp.39-48, 1917. ,
Evolution strategies with cumulative step length adaptation on the noisy parabolic ridge, Natural Computing, vol.2, issue.2, 2006. ,
DOI : 10.1007/s11047-006-9025-5
Cumulative Step Length Adaptation for Evolution Strategies Using Negative Recombination Weights, EvoWorkshops, pp.545-554, 2008. ,
DOI : 10.1007/978-3-540-78761-7_60
Finite time analysis of the multiarmed bandit problem, Machine Learning, vol.47, issue.2/3, pp.235-256, 2002. ,
DOI : 10.1023/A:1013689704352
Convergence results for the <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mo stretchy="false">(</mml:mo><mml:mn>1</mml:mn><mml:mo>,</mml:mo><mml:mi>??</mml:mi><mml:mo stretchy="false">)</mml:mo></mml:math>-SA-ES using the theory of <mml:math altimg="si2.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>??</mml:mi></mml:math>-irreducible Markov chains, Theoretical Computer Science, vol.334, issue.1-3, pp.35-69, 2005. ,
DOI : 10.1016/j.tcs.2004.11.017
On a modification of chebyshev's inequality and of the error formula of laplace. Original publication, Ann. Sci. Inst. Sav. Ukraine, Sect. Math, vol.1, issue.31, pp.38-49, 1924. ,
The Theory of Probabilities, 1946. ,
The Theory of Evolutions Strategies, 2001. ,
DOI : 10.1007/978-3-662-04378-3
Global convergence for evolution strategies in spherical problems: some simple proofs and difficulties, Theoretical Computer Science, vol.306, issue.1-3, pp.269-289, 2003. ,
DOI : 10.1016/S0304-3975(03)00284-6
A Measure of Asymptotic Efficiency for Tests of a Hypothesis Based on the sum of Observations, The Annals of Mathematical Statistics, vol.23, issue.4, pp.493-509, 1952. ,
DOI : 10.1214/aoms/1177729330
A probabilistic Theory of Pattern Recognition, 1997. ,
DOI : 10.1007/978-1-4612-0711-5
Genetic algorithms in noisy environments, Machine Learning, pp.101-120, 1988. ,
DOI : 10.1007/BF00113893
Comparison-Based Algorithms Are Robust and Randomized Algorithms Are Anytime, Evolutionary Computation, vol.26, issue.3, pp.411-434, 2007. ,
DOI : 10.1137/0801010
URL : https://hal.archives-ouvertes.fr/inria-00173221
Evolution strategies on noisy functions how to improve convergence properties, Parallel Problem Solving From Nature, pp.159-168, 1994. ,
DOI : 10.1007/3-540-58484-6_260
Completely Derandomized Self-Adaptation in Evolution Strategies, Evolutionary Computation, vol.9, issue.2, 2003. ,
DOI : 10.1016/0004-3702(95)00124-7
Hoeffding and Bernstein races for selecting policies in evolutionary direct policy search, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, pp.401-408, 2009. ,
DOI : 10.1145/1553374.1553426
Probability Inequalities for Sums of Bounded Random Variables, Journal of the American Statistical Association, vol.1, issue.301, pp.13-30, 1963. ,
DOI : 10.1214/aoms/1177730491
On Multiplicative Noise Models for Stochastic Search, Parallel Problem Solving From Nature, dortmund Allemagne, 2008. ,
DOI : 10.1007/978-3-540-87700-4_6
URL : https://hal.archives-ouvertes.fr/inria-00287725
Asymptotically efficient adaptive allocation rules, Advances in Applied Mathematics, vol.6, issue.1, pp.4-22, 1985. ,
DOI : 10.1016/0196-8858(85)90002-8
Hoeffding races: Accelerating model selection search for classification and function approximation, Advances in neural information processing systems 6, pp.59-66, 1994. ,
The Racing Algorithm: Model Selection for Lazy Learners, Artificial Intelligence Review, vol.11, pp.193-225, 1997. ,
DOI : 10.1007/978-94-017-2053-3_8
Empirical Bernstein stopping, Proceedings of the 25th international conference on Machine learning, ICML '08, pp.672-679, 2008. ,
DOI : 10.1145/1390156.1390241
URL : https://hal.archives-ouvertes.fr/hal-00834983
Evolutionstrategie: Optimierung Technischer Systeme nach Prinzipien des Biologischen Evolution, 1973. ,
Numerical Optimization of Computer Models, 1981. ,
On the adaptation of noise level for stochastic optimization, 2007 IEEE Congress on Evolutionary Computation, 2007. ,
DOI : 10.1109/CEC.2007.4424857
URL : https://hal.archives-ouvertes.fr/inria-00173224
