Computing Nearest Gcd with Certification
A bisection method, based on exclusion and inclusion tests, is used to address the nearest univariate gcd problem formulated as a bivariate real minimization problem of a rational fraction. The paper presents an algorithm, a first implementation and a complexity analysis relying on Smale's $\alpha$-theory. We report its behavior on an illustrative example.
