HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Flexible interconnection network for dynamically and partially reconfigurable architectures
Abstract : The dynamic and partial reconfiguration of FPGAs enables the dynamic placement in reconfigurable zones of the tasks that describe an application. However, the dynamic management of the tasks impacts the communications since tasks are not present in the FPGA during all computation time. So, the task manager should ensure the allocation of each new task and their interconnection which is performed by a flexible interconnection network. In this article, various communication architectures, in particular interconnection networks, are studied. Each architecture is evaluated with respect to its suitability for the paradigm of the dynamic and partial reconfiguration in FPGA implementations. This study leads us to propose the DRAFT network that supports the communication constraints into the context of dynamic reconfiguration. We also present DRAGOON, the automatic generator of networks, which allows to implement and to simulate the DRAFT topology. Finally, DRAFT and the two most popular Networks-on-Chip are implemented in several configurations using DRAGOON, and compared considering real implementation results.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00437763
Contributor : Daniel Chillet Connect in order to contact the contributor
Submitted on : Tuesday, December 1, 2009 - 2:04:00 PM
Last modification on : Thursday, January 20, 2022 - 4:20:19 PM
Identifiers
  • HAL Id : inria-00437763, version 1
Citation
Ludovic Devaux, Sana Ben Sassi, Sebastien Pillement, Daniel Chillet, Didier Demigny. Flexible interconnection network for dynamically and partially reconfigurable architectures. International Journal of Reconfigurable Computing, Hindawi Publishing Corporation, 2010. ⟨inria-00437763⟩
Share
Metrics
Record views
179
