Skeletal implicit surface reconstruction from sections for flexible body simulation, Proceedings of the Fifth International Conference on Information Visualisation, p.723, 2001. ,
An implicit surface polygonizer, Graphics gems IV, pp.324-349, 1994. ,
Shape reconstruction from planar cross sections, Computer Vision Graphics and Image Processing, vol.44, issue.1, 1988. ,
Matisse: Painting 2d regions for modeling free-form shapes, In SBIM, pp.57-64, 2008. ,
Convolution surfaces, Computer Graphics, vol.25, issue.4, pp.251-256, 1991. ,
A triangulation algorithm from arbitrary shaped multiple planar contours, ACM Transactions on Graphics, vol.10, issue.2, p.182, 1991. ,
Optimal surface reconstruction from planar contours, Communications of the ACM, vol.20, pp.10-693, 1977. ,
Surface reconstruction from unorganized points, SIGGRAPH 92, pp.71-78, 1992. ,
A new approach to the construction of surfaces from contour data, In Computer Graphics Forum, vol.13, pp.75-84, 1994. ,
Building 3d surface networks from 2d curve networks with application to anatomical modeling, The Visual Computer, vol.21, pp.8-10, 2005. ,
Approximating complex surfaces by triangulation of contours lines, IBM Journal of Research and Development, vol.19, issue.1, pp.2-11, 1975. ,
Reconstruction and simplification of surfaces from contours, Graphical models, vol.62, issue.6, pp.429-443, 2000. ,
Surface Reconstruction From Non-parallel Curve Networks, Computer Graphics Forum, Proceedings of Eurographics, pp.155-163, 2008. ,
DOI : 10.1111/j.1467-8659.2008.01112.x
Surfaces from contours, ACM Trans. Graph, vol.11, issue.3, pp.228-258, 1992. ,
Interpolating implicit surfaces from scattered surface data using compactly supported radial basis functions, SIGGRAPH 2005 Courses, p.78, 2005. ,
Shape transformation using variational implicit functions, SIGGRAPH 99, pp.335-342, 1999. ,
Prototype modeling from sketched silhouettes based on convolution surfaces, Computer Graphics Forum, vol.23, pp.71-83, 2004. ,
Implicit surface reconstruction and deformation using the level set method, Tech. rep., Group in Computational and Applied Mathematics, 2001. ,
