New interface
Journal articles
Spatio-temporal Coding to Improve Speed and Noise Tolerance of On-chip Interconnect
Abstract : This paper introduces a new coding scheme that simultaneously tackles different design issues of interconnections such as noise, crosstalk and power consumption. The scheme is based on temporal skewing between data words on even and odd lines of an interconnection link, and its hardware implementation is simple and area-efficient. The proposed scheme permits to double the bandwidth of the interconnect while improving its noise tolerance. This is achieved through the simultaneous use of two error detecting techniques: temporal redundancy and parity. Improved noise tolerance property provided by our design enables to decrease the power supply voltage and hence to reduce power consumption of the interconnect.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00438322
Contributor : Sébastien Pillement Connect in order to contact the contributor
Submitted on : Thursday, December 3, 2009 - 12:12:12 PM
Last modification on : Thursday, February 17, 2022 - 10:08:03 AM
Identifiers
Citation
Sébastien Pillement, Jm. Philippe, Olivier Sentieys. Spatio-temporal Coding to Improve Speed and Noise Tolerance of On-chip Interconnect. Microelectronics Journal, 2010, ⟨10.1016/j.mejo.2009.11.001⟩. ⟨inria-00438322⟩
Share
Metrics
Record views
370
