A Fast Level Set Method for Propagating Interfaces, Journal of Computational Physics, vol.118, issue.2, p.269277, 1995. ,
DOI : 10.1006/jcph.1995.1098
Robust and ecient cartesian mesh generation for component-based geometry, 1997. ,
A Paradigm for the Robust Design of Algorithms for Geometric Modeling, Computer Graphics Forum, vol.13, issue.3, p.3344, 1994. ,
DOI : 10.1111/1467-8659.1330033
Aabb tree, 2009. ,
Photorealistic scene reconstruction by voxel coloring, International Journal of Computer Vision, vol.35, issue.2, p.151173, 1999. ,
The power crust, unions of balls, and the medial axis transform, Computational Geometry, vol.19, issue.2-3, p.127153, 2001. ,
DOI : 10.1016/S0925-7721(01)00017-7
Geometric Modeling for Computer Vision, 1974. ,
Approximate Boolean operations on free-form solids, Proceedings of the 28th annual conference on Computer graphics and interactive techniques , SIGGRAPH '01, p.185194, 2001. ,
DOI : 10.1145/383259.383280
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.9.9989
CGAL-3.2 User and Reference Manual, 2006. ,
Stepwise construction of polyhedra in geometric modelling, Mathematical Methods in Computer Graphics and Design, 1978. ,
A level-set approach for the metamorphosis of solid models, IEEE Transaction on Visualization and Computer Graphics, vol.7, issue.2, p.173192, 2001. ,
Point in Polyhedron Testing Using Spherical Polygons, Graphics Gem V, chapter, p.4249, 1995. ,
DOI : 10.1016/B978-0-12-543457-7.50015-2
Deformable curve and surface nite-elements for free-form shape design, Computer Graphics, pp.257-266, 1991. ,
Shape representation and image segmentation using deformable surfaces, Image and Vision Computing, p.132145, 1992. ,
DOI : 10.1016/0262-8856(92)90065-b
URL : https://hal.archives-ouvertes.fr/inria-00615539
Shape Reconstruction from 3D and 2D Data Using PDE-Based Deformable Surfaces, Proceedings of European Conference on Computer Vision, p.238251, 2004. ,
DOI : 10.1007/978-3-540-24672-5_19
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.115.4221
Simulation of simplicity: A technique to cope with degenerate cases in geometric algorithms, ACM Transactions on Graphics, vol.9, issue.1, p.66104, 1990. ,
A Hybrid Particle Level Set Method for Improved Interface Capturing, Journal of Computational Physics, vol.183, issue.1, p.83116, 2002. ,
DOI : 10.1006/jcph.2002.7166
Animation and rendering of complex water surfaces, Proceedings of SIGGRAPH, p.736744, 2002. ,
Computer Graphics: Principles and Practice, second edition, 1996. ,
Computer Graphics: Principles and Practice, 1990. ,
Exact polyhedral visual hulls, Procedings of the British Machine Vision Conference 2003, p.329338, 2003. ,
DOI : 10.5244/C.17.32
URL : https://hal.archives-ouvertes.fr/inria-00349075
Ecient polyhedral modeling from silhouettes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.31, issue.3, p.414427, 2009. ,
DOI : 10.1109/tpami.2008.104
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.226.8683
Accurate, Dense, and Robust Multi-View Stereopsis, 2007 IEEE Conference on Computer Vision and Pattern Recognition, 2009. ,
DOI : 10.1109/CVPR.2007.383246
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.117.5027
Fast constructive-solid geometry display in the pixel-powers graphics system, Proceedings of SIGGRAPH, p.107116, 1986. ,
Cutting and stitching: Converting sets of polygons to manifold surfaces, IEEE Transaction on Visualization and Computer Graphics, vol.7, issue.2, p.136151, 2001. ,
Silhouette and stereo fusion for 3D object modeling, Computer Vision and Image Understanding, vol.96, issue.3, pp.367-392, 2004. ,
DOI : 10.1016/j.cviu.2004.03.016
dD convex hulls and delaunay triangulations ,
Surface reconstruction from unorganized points, Proceedings of SIG- GRAPH, 1992. ,
DOI : 10.1145/133994.134011
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.153.4735
Constructive solid geometry for triangulated polyhedra, 1990. ,
3D distance elds: A survey of techniques and applications, IEEE Transactions on Visualization and Compute Graphics, vol.12, issue.4, p.581599, 2006. ,
Dual contouring of hermite data, Proceedings of SIGGRAPH, 2002. ,
Self-intersection removal in triangular mesh osetting, Computer-Aided Design and Applications, vol.1, issue.14, p.477484, 2004. ,
Intersecting sequences of dD iso-oriented boxes, CGAL-3.2 User and Reference Manual, 2006. ,
Multiresolution Shape Deformations for Meshes with Dynamic Vertex Connectivity, Proceedings of Eurographics, p.249260, 2000. ,
DOI : 10.1111/1467-8659.00417
Feature sensitive surface extraction from volume data, Proceedings of the 28th annual conference on Computer graphics and interactive techniques , SIGGRAPH '01, p.5766, 2001. ,
DOI : 10.1145/383259.383265
Deformable model with adaptive mesh and automated topology changes, Fourth International Conference on 3-D Digital Imaging and Modeling, 2003. 3DIM 2003. Proceedings., 2003. ,
DOI : 10.1109/IM.2003.1240227
URL : https://hal.archives-ouvertes.fr/hal-00308201
Marching cubes: A high resolution 3D surface construction algorithm, Computer Graphics, vol.21, issue.4, p.163169, 1987. ,
DOI : 10.1145/37401.37422
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.132.3930
Spatially adaptive techniques for level set methods and incompressible ow. Computers and Fluids, pp.995-1010, 2006. ,
DOI : 10.1016/j.compfluid.2005.01.006
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.476.7355
Boolean operations of 2-manifolds through vertex neighborhood classication, ACM Transactions on Graphics, vol.5, issue.1, p.129, 1986. ,
T-snakes: Topology adaptive snakes, Medical Image Analysis, vol.4, issue.2, p.7391, 2000. ,
DOI : 10.1016/S1361-8415(00)00008-6
Discrete dierential geometry operators for triangulated 2-dimensional manifolds, Proceedings of VisMath, 2002. ,
Trimming for subdivision surfaces, 2000. ,
Dynamic mesh optimization for polygonized implicit surfaces with sharp features, The Visual Computer, vol.19, p.115126, 2003. ,
Level Set Methods and Dynamic Implicit Surfaces, 2003. ,
DOI : 10.1115/1.1760520
URL : http://dx.doi.org/10.1016/s0898-1221(03)90179-9
Geometric Level Set Methods in Imaging, Vision, and Graphics, 2003. ,
Fronts propagating with curvature-dependent speed: Algorithms based on Hamilton-Jacobi formulations, Journal of Computational Physics, vol.79, issue.1, p.1249, 1988. ,
DOI : 10.1016/0021-9991(88)90002-2
A non-selfintersection adaptive deformable surface for complex doundary extraction from volumetric images, Computer & Graphics, vol.25, p.421440, 2001. ,
Delaunay Deformable Models: Topology-Adaptive Meshes Based on the Restricted Delaunay Triangulation, 2007 IEEE Conference on Computer Vision and Pattern Recognition, p.18, 2007. ,
DOI : 10.1109/CVPR.2007.383019
URL : https://hal.archives-ouvertes.fr/hal-00488042
Multi-View Stereo Reconstruction and Scene Flow Estimation with a Global Image-Based Matching Score, International Journal of Computer Vision, vol.24, issue.2, pp.179-193, 2007. ,
DOI : 10.1007/s11263-006-8671-5
Interactive Boolean operations for conceptual design of 3-D solids, Proceedings of the 24th annual conference on Computer graphics and interactive techniques , SIGGRAPH '97, p.269278, 1997. ,
DOI : 10.1145/258734.258865
Encyclopedia of Electrical and Electronics Engineering, chapter Solid Modeling, 1999. ,
A Comparison and Evaluation of Multi-View Stereo Reconstruction Algorithms, 2006 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, Volume 1 (CVPR'06), p.519526, 2006. ,
DOI : 10.1109/CVPR.2006.19
Ecient topology construction from triangle soup, Proceedings of the Geometric Modeling and PRocessing, 2004. ,
A level set approach for computing solutions to incompressible two-phase ow, Journal of Computational Physics, vol.114, issue.1, p.146159, 1994. ,
Temporal Surface Tracking Using Mesh Evolution, Proceedings of European Conference on Computer Vision, 2008. ,
DOI : 10.1007/978-3-540-88688-4_3
URL : https://hal.archives-ouvertes.fr/inria-00590255
Towards high-resolution large-scale multi-view stereo, Conference on Computer Vision and Pattern Recognition (CVPR), 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00834903
Deforming meshes that split and merge, Proceedings of SIGGRAPH, 2009. ,
Fast viscoelastic behavior with thin features, Proceedings of SIGGRAPH, 2008. ,
Robust Factorization Methods Using a Gaussian/Uniform Mixture Model, International Journal of Computer Vision, vol.26, issue.7, 2009. ,
DOI : 10.1007/s11263-008-0169-x
URL : https://hal.archives-ouvertes.fr/inria-00446987
Fast software for box intersection, International Journal of Compational Geometry and Applications, vol.12, issue.1 2, p.143172, 2002. ,
