Homotopic Fréchet Distance Between Curves or, Walking Your Dog in the Woods in Polynomial Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Geometry Année : 2010
The Fréchet distance between two curves in the plane is the minimum length of a leash that allows a dog and its owner to walk along their respective curves, from one end to the other, without backtracking. We propose a natural extension of Fréchet distance to more general metric spaces, which requires the leash itself to move continuously over time. For example, for curves in the punctured plane, the leash cannot pass through or jump over the obstacles (``trees''). We describe a polynomial-time algorithm to compute the homotopic Fréchet distance between two given polygonal curves in the plane minus a given set of polygonal obstacles.
frechet.pdf (675.3 Ko) Télécharger le fichier
2010 Homotopic Frechet Distance Between Curves.png (15.43 Ko) Télécharger le fichier
Format : Figure, Image
inria-00438463 , version 1 (03-12-2009)
Erin Wolf Chambers, Eric Colin de Verdière, Jeff Erickson, Sylvain Lazard, Francis Lazarus, et al.. Homotopic Fréchet Distance Between Curves or, Walking Your Dog in the Woods in Polynomial Time. Computational Geometry, 2010, Special Issue on 24th Annual Symposium on Computational Geometry (SoCG'08), 43 (3), pp.295-311. ⟨10.1016/j.comgeo.2009.02.008⟩. ⟨inria-00438463⟩
1059 Consultations
234 Téléchargements
