Gaussian and non-Gaussian processes of zero power variation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
This paper considers the class of stochastic processes $X$ which are Volterra convolutions of a martingale $M$. When $M$ is Brownian motion, $X$ is Gaussian, and the class includes fractional Brownian motion and other Gaussian processes with or without homogeneous increments. Let $m$ be an odd integer. Under some technical conditions on the quadratic variation of $M$, it is shown that the $m$-power variation exists and is zero when a quantity $\delta^{2}(r) $ related to the variance of an increment of $M$ over a small interval of length $r$ satisfies $\delta(r) = o(r^{1/(2m)}) $. In the case of a Gaussian process with homogeneous increments, $\delta$ is $X$'s canonical metric and the condition on $\delta$ is proved to be necessary, and the zero variation result is extended to non-integer symmetric powers. In the non-homogeneous Gaussian case, when $m=3$, the symmetric (generalized Stratonovich) integral is defined, proved to exist, and its Itô's formula is proved to hold for all functions of class $C^{6}$.
MartConvSent09.pdf (379.55 Ko) Télécharger le fichier
inria-00438532 , version 1 (03-12-2009)
inria-00438532 , version 2 (28-05-2012)
  • HAL Id : inria-00438532 , version 1
  • ARXIV : 0912.0782
Francesco Russo, Frederi Viens. Gaussian and non-Gaussian processes of zero power variation. 2009. ⟨inria-00438532v1⟩
200 Consultations
310 Téléchargements
