Real time trajectory prediction for collision risk estimation between vehicles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, we present our approach for collision risk estimation between vehicles. The vehicles are equipped with GPS receivers and communication devices. Our approach consists on using the knowledge given trough communication tool to predict the trajectories of the surrounding vehicles. Based on these trajectories, we identify the configurations of the collisions between vehicles. The risk is calculated using several indicators that are reflecting not only the possible collisions but also the dangerousness of these collisions. Our algorithm is tested on crossroads using scenarios involving real prototypes producing realistic scenarios
Ammoun_Cluj2008.pdf (1.29 Mo) Télécharger le fichier
inria-00438624 , version 1 (04-12-2009)
  • HAL Id : inria-00438624 , version 1
Samer Ammoun, Fawzi Nashashibi. Real time trajectory prediction for collision risk estimation between vehicles. ICCP 2009, Aug 2009, CLUJ NAPOCA, Romania. ⟨inria-00438624⟩
Collections
INRIA INRIA2
224 Consultations
3102 Téléchargements
