Implementation of Bourbaki's Elements of Mathematics in Coq: Part Two; Ordered Sets, Cardinals, Integers
We believe that it is possible to put the whole work of Bourbaki into a computer. One of the objectives of the Gaia project concerns homological algebra (theory as well as algorithms); in a first step we want to implement all nine chapters of the book Algebra. But this requires a theory of sets (with axiom of choice, etc.) more powerful than what is provided by Ensembles; we have chosen the work of Carlos Simpson as basis. This reports lists and comments all definitions and theorems of the Chapter ''Ordered Sets, Cardinals, Integers''. Version 3 is based on the Coq ssreflect library. Version 5 implements many properties of ordinal numbers and infinite cardinal numbers. Version 6 includes the Veblen hierarchy of ordinals, the Schütte function psi, and a bit of theory of models. The code (including some exercises) is available on the Web, under http://www-sop.inria.fr/apics/gaia .
