Conference papers
Towards Adaptable Control Flow Segmentation for Measurement-Based Execution Time Analysis
Abstract : During the design of embedded real-time systems, engineers have to consider the temporal behavior of software running on a particular hardware platform. Measurement-based timing analysis is a technique that combines elements from static code analysis with execution time measurements on real physical hardware. Because performing exhaustive measurement is generally not tractable, some kind of abstraction must be used to deal with the combinatoric complexity of real software. We propose an adaptable measurement-based analysis approach that uses the novel flexible abstraction of a segment graph to model control flow at varying levels of detail. We also present preliminary experimental results produced by a prototype implementation.
Document type :
Conference papers
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/inria-00441958
Contributor : Alain Monteil Connect in order to contact the contributor
Submitted on : Thursday, December 17, 2009 - 4:53:25 PM
Last modification on : Wednesday, October 13, 2021 - 7:58:04 PM
Long-term archiving on: : Thursday, June 17, 2010 - 8:57:36 PM
File
TimingAnalysis_Zolda.pdf
Identifiers
  • HAL Id : inria-00441958, version 1
Collections
Citation
Michael Zolda, Sven Bünte, Raimund Kirner. Towards Adaptable Control Flow Segmentation for Measurement-Based Execution Time Analysis. 17th International Conference on Real-Time and Network Systems, Oct 2009, Paris, France. pp.35-44. ⟨inria-00441958⟩
Share
Metrics
Record views
123
Files downloads
236
