SQPpro - A solver of nonlinear optimization problems, using an SQP approach
Abstract : SQPpro is a piece of software that aims at solving a nonlinear optimization problem with nonlinear equality and inequality constraints. The functions defining the problem must be at least once differentiable. The implemented algorithm uses an SQP approach, which is a workable version of the Newton and quasi-Newton methods. The quadratic optimization that has to be solved at each iteration uses the solver QPAL. The constraint Jacobian matrices can be strored in dense or sparse structures; in addition the Hessian of the Lagrangien can be approximated by the BFGS (dense) or $\ell$-BFGS (sparse) formula. SQPpro is written in Fortran-2003.
Type de document :
Rapport
[Technical Report] INRIA. 2009, pp.24
Liste complète des métadonnées
Littérature citée [8 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00442314
Contributeur : Jean Charles Gilbert <>
Soumis le : samedi 19 décembre 2009 - 19:38:16
Dernière modification le : mardi 17 avril 2018 - 11:32:10
Document(s) archivé(s) le : jeudi 17 juin 2010 - 23:57:26
Fichier
RT-0378.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00442314, version 1
Collections
Citation
Jean Charles Gilbert. SQPpro - A solver of nonlinear optimization problems, using an SQP approach. [Technical Report] INRIA. 2009, pp.24. 〈inria-00442314〉
Métriques
Consultations de la notice
189
Téléchargements de fichiers
95
