New interface
Conference papers
Diesel Particulate Filter Thermal Management Using Model-Based Design
Abstract : Diesel Particulate Filters (DPF) are now considered as efficient solutions to reduce Diesel PM emissions. Concerned by environment, Renault will equip all serial production Diesel vehicles with this technology. The main issue for these devices is the periodical regeneration necessary to eliminate the accumulated soot. The challenging enhancement of the regeneration event can be achieved with a better regeneration temperature control. For this purpose, a controller based on a physical model is proposed to manage the DPF temperature during active regeneration. This paper describes the methodology which has been followed to design this controller. In a first step, a reduced physical model has been developed and validated with experimental data. In a second step, two model-based controllers have been studied: a robust LPV (Linear Parameter Varying) and a gain scheduling PID..Special attention has been paid to the simplification as far as possible of the controller tuning process. Thus, the calibration parameters are only dependent upon some physical parameters and performance requirements of the closed-loop control: bandwidth, maximum overshoot. Performance robustness has been assessed in simulation. The whole modeling, controller design and validation, as well as robustness analysis have been performed using Matlab/Simulink®. Finally, the strategy has been validated on a vehicle using rapid prototyping tools.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00442351
Contributor : Michel Sorine Connect in order to contact the contributor
Submitted on : Monday, December 21, 2009 - 12:56:46 AM
Last modification on : Friday, January 21, 2022 - 3:14:07 AM
Identifiers
  • HAL Id : inria-00442351, version 1
Collections
Citation
Fehd Benaicha, Karim Bencherif, Stéphane Sadaï, Michel Sorine. Diesel Particulate Filter Thermal Management Using Model-Based Design. SAE World Congress & Exhibition, SAE International, Apr 2009, Detroit, MI, United States. ⟨inria-00442351⟩
Share
Metrics
Record views
184
