Convex hulls of bounded curvature
In this paper, we consider the problem of computing a convex hull of bounded curvature of a set S of points in the plane, i.e., a set containing S and whose boundary is a curve of bounded curvature of minimal length. We prove that, if the radius of the smallest disk that contains S is greater than 1, such a hull is unique. We show that the computation of a convex hull of bounded curvature reduces to convex programming or to solving a set of algebraic systems.
Géométrie algorithmique [cs.CG]
