Towards a Generic Framework to Generate Explanatory Traces of Constraint Solving and Rule-Based Reasoning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Pierre Deransart
  • Fonction : Auteur
  • PersonId : 833574
Rafael Oliveira
  • Fonction : Auteur
  • PersonId : 865759
In this report, we show how to use the Simple Fluent Calculus (SFC) to specify generic tracers, i.e. tracers which produce a generic trace. A generic trace is a trace which can be produced by different implementations of a software component and used independently from the traced component. This approach is used to define a method for extending a java based CHRor platform called CHROME (Constraint Handling Rule Online Model-driven Engine) with an extensible generic tracer. The method includes a tracer specification in SFC, a methodology to extend it, and the way to integrate it with CHROME, resulting in the platform CHROME-REF (for Reasoning Explanation Facilities), which is a constraint solving and rule based reasoning engine with explanatory traces.
report.pdf (844.34 Ko) Télécharger le fichier
inria-00443635 , version 1 (12-01-2010)
  • HAL Id : inria-00443635 , version 1
  • ARXIV : 1001.2188
Pierre Deransart, Rafael Oliveira. Towards a Generic Framework to Generate Explanatory Traces of Constraint Solving and Rule-Based Reasoning. [Research Report] RR-7165, INRIA. 2009, pp.53. ⟨inria-00443635⟩
127 Consultations
275 Téléchargements
