Exit,apl0] [19,2,1,Exit,apl] [69,8,4,Exit,fib] [20,1,0,Exit,goal] [70,8,4,mg,3] [21,5,3,Redo,fib,c2, action, vol.125176365125183681957120472204533386233811176931226, issue.6222555, pp.1-4 ,
Firsts : ([],false) ([1],false) ([1,1],false), apl0) ([1,1apl0) . Clauses : ([],[g]) ([1],[c3]) ([1,1]false) . Comp tree: false . Fld tree : false . Go to bkp: false . FibSeq: [(30,1), 2003. ,
Holds(Cuno(u), z) ? ¬Holds(F st(u), z) ? ¬Holds(Ct, z) ? ¬Holds(Bkt, z) ? ¬Holds(F lr(, p.? mhnb(u) inf luence(scs(t ,
Holds(Cuno(u), z) ? ¬Holds(F st(u), z) ? ¬Holds(Ct, z) ? ¬Holds(Bkt, z) ? Holds(F lr ,
Cuno(u) Action FailRdo P oss(F ailD, Holds(Cuno(u), z) ? ¬Holds(F st(u), z) ? ¬Holds(Ct, z) ? ¬Holds(Bkt, z) ? Holds(F lr(p), z) ? hcp ,
y)|y > v} ? {Cl(y, )|y > v} ? Ct ? Bkt(v) Action RdoF P oss(RedoD ,
y)|y > v} ? {Cl(y, )|y > v} ? Ct ? Bkt(v) Action Rdo2 ,
Holds(Cl(v, cl)) ? Holds(num(n)) ? (w = ncpd 1 (v) ? pd = ncpd 2 (w)) ,
y, )|y > v} ? {Cl(y, )|y > v} ? {F st(y)|y > v} ? Ct ? Bkt(v) Action Final P oss(F inal, Holds(Cuno(u), z) ? ¬Holds(F st(u), z) ? Holds(Ct, z) ? ¬Holds(Bkt, z) ? (u = [] ? ¬hcp ,
State(s)) ? State(Do(Init,[initState, goal(q) ,
? (?q)(Holds(Goal(q {c}), z) The Solve Precondition Axiom states that the only precondition for the Solve action on the built-in constraint c is that this constraint should be in the goal ,
State(Do(Solve, [solve, bic(c), goal(q) ,
State(s)) ? Holds(U dcs(u), State(s))? Holds(N extId(n), State(s)) ?, Introduce ,
? (?e)(?b)(M atch(h k , h R , u 1, id(u 2 ), r), z) ? Bics(b, z)? Entails(b, e, g)) ,
State(s)) ? Holds(Goal(q), State(s))? M atch(h k , h R , u 1 , u 2 , e, z) ? State(Do(Apply, [apply, rule(r@h k \h R ? g|d, State(s))? Holds(U dcs(u 1 u 2 u), p.goal udc bic ,
Holds(goal(q), z)? ?P oss(Apply, [r, h k , h R , g ,
State(Do(F ail, [fail, goal(q)], s)) = State(s) Observational Semantics Pickup P oss(P ickup, [a, o, r], s) ? Holds(AgentInRoom(a, r), s) ? Holds(ObjectInRoom(o, r), s)? ¬Holds(Carries ,
Holds(Carries(a, o)) ? Holds, AgentInRoom ,
State(Do(Drop, [drop, a, o, r], s)) = State(s) ? Carries ,
Holds(AgentInRoom(a, r), s)? (?r )Connects(r, d, r ) ? ¬(?d )Holds(AtDoor ,
State(Do(GoT oDoor, [walk, a, d], s)) = State(s) ? AtDoor ,
Holds(AgentInRoom(a, r))? Holds(AtDoor(a, d), s) ? Connects(r, d, r ) ? ¬Holds(Closed(d), s)) ,
State(Do(EnterRoom, [walk, a, r ], s)) = State(s)?AgentInRoom(a, r )? AgentInRoom ,
Holds(AtDoor(a, d), s) ? Holds(HasKeyCode(a, d), s)? Holds(Closed(d), s) ,
State(Do(Open, [open, a, d], s)) = State(s) ? Closed(d) ,
Structural Operational Semantics, Handbook of Process Algebra, pp.197-292, 2001. ,
Lectures on Semantics: The Initial Algebra and Final Coalgebra Perspectives, Logic of Computation, 1997. ,
DOI : 10.1007/978-3-642-59048-1_1
Debugging Systems for Constraint Programming (DiS- CiPl) -D.WP1.1.M1.1-1 -CP Debugging Needs, Inria Rocquencourt Esprit Projet, 1997. ,
Reasoning on the Web with Rules and Semantics, 2004. ,
Automata for modelling real time systems, Proceedings of ICALP'90, pp.322-335, 1990. ,
Discrete abstractions of hybrid systems, Proceedings of the IEEE, pp.971-984, 2000. ,
DOI : 10.1109/5.871304
A Traceability Engine Dedicated to Model Transformation for Software Engineering ,
An abstract semantics and concrete language for continuous queries over streams and relations, 2002. ,
La révolution technologique de la grammatisation. IntroductionàIntroduction`Introductionà l'histoire des sciences du langage, 1994. ,
A simple solution to the Yale Shooting problem, Proceedings of the International Conference on Principles of Knowledge Representation and Reasoning (KR), pp.11-20, 1989. ,
Ilog visual cp, p.4, 2004. ,
Timed Automata with non observable actions : expressive power end refinement, 1997. ,
Introduction ausì ecle des menaces, Odile Jacob, 2004. ,
Detecting model inconsistency through operation-based model construction, Proceedings of the 13th international conference on Software engineering , ICSE '08, pp.511-520, 2008. ,
DOI : 10.1145/1368088.1368158
URL : https://hal.archives-ouvertes.fr/hal-01303728
On the role of semantic approximations on validation and diagnosis of contraint logic programs Vannevar Bush. As we May Think. The Atlantic Monthly The electronic version was prepared by Denys Duchier, AADEBUG, pp.155-169, 1945. ,
Understanding the control flow of Prolog programs, Logic Programming Workshop, 1980. ,
A Cost-Based Approach to Adaptive Resource Management in Data Stream Systems, IEEE Transactions on Knowledge and Data Engineering, vol.20, issue.2, pp.230-245, 2008. ,
DOI : 10.1109/TKDE.2007.190686
Biologie de la mémoire, Odile Jacob, 2006. ,
Modèlisation et construction de traces d'utilisation d'une activité d'apprentissage : une approche langage pour la réingénierie d'un EIAH, Revue STICEF, vol.14, 2007. ,
Orna Grumberg, and Doron A. Peled. Model Checking, 1999. ,
Model Checking, 2000. ,
Model checking and abstraction, ACM Transactions on Programming Languages and Systems, vol.16, issue.5, pp.1512-1542, 1992. ,
DOI : 10.1145/186025.186051
A Theory of Observables for Logic Programs, Information and Computation, vol.169, issue.1, pp.23-80, 2001. ,
DOI : 10.1006/inco.2000.3024
Systematic design of program transformation frameworks by abstract interpretation, Proc. of POPL 2002, pp.178-190, 2002. ,
Abstract interpretation, Proceedings of the 4th ACM SIGACT-SIGPLAN symposium on Principles of programming languages , POPL '77, pp.238-252, 1977. ,
DOI : 10.1145/512950.512973
URL : https://hal.archives-ouvertes.fr/inria-00528590
Abstract interpretation and application to logic programs, The Journal of Logic Programming, vol.13, issue.2-3, pp.103-179, 1992. ,
DOI : 10.1016/0743-1066(92)90030-7
Visualisation de traces : Application aux traces réflexives d'elycée, 2007. ,
Introduction to the semantic web, Spinning the Semantic Web. Bringing the World Wide Web to Its Full Potential, pp.1-25, 2003. ,
Aux limites des mathématiques et de l'informatique . Belin -pour la science, 2006. ,
On using Tracer Driver for External Dynamic Process Observation, Proceedings of the 16th Workshop on Logic-based Methods in Programming Environments, p.6, 2006. ,
Conception de Trace et Applications (vers une méta-théorie des traces), 2009. ,
The Standard ; Reference Manual, 1996. ,
Une sémantique observationnelle du modèle des bo??tesbo??tes pour la résolution de programmes logiques, Actes destroisì emes Journées Francophones de Programmation par Contraintes, JFPC 07, 2007. ,
Une sémantique observationnelle du modèle des bo??tesbo??tes pour la résolution de programmes logiques (versionétendue versionétendue) RR-6229, INRIA, 2007. ,
A grammatical view of logic programming, 1993. ,
DOI : 10.1007/3-540-50820-1_50
URL : https://hal.archives-ouvertes.fr/inria-00075671
GNU-Prolog, a free Prolog compiler with constraint solving over finite domains, 2003. ,
Design and implementation of the GNU-Prolog system, Journal of Functional and Logic Programming, pp.6-10, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00693240
The Book of Traces, 1995. ,
DOI : 10.1142/2563
Automated Analysis of CLP(FD) Program Execution Traces, Proceedings of the International Conference on Logic Programming. Lecture Notes in Computer Science, 2002. ,
DOI : 10.1007/3-540-45619-8_35
Logic programming environments: Dynamic program analysis and debugging, The Journal of Logic Programming, vol.19, issue.20, pp.351-384, 1994. ,
DOI : 10.1016/0743-1066(94)90030-2
Scénarios : un paradigme permettant la mise en oeuvre de stratégies de localisation d'erreurs de programmation. InPremì ere ERGO- IA, 1988. ,
State-of-the-art of enabling technologies for packing and planning in future wms, D3.1, European Project, STREP Net-WMS Constraint Optimization in Wharehouse Management Systems ,
Abstract interpretation and types for systems biology, Theoretical Computer Science, vol.403, issue.1, 2007. ,
DOI : 10.1016/j.tcs.2008.04.024
URL : https://hal.archives-ouvertes.fr/hal-01431355
The InfoVis Toolkit, IEEE Symposium on Information Visualization, 2005. ,
DOI : 10.1109/INFVIS.2004.64
URL : https://hal.archives-ouvertes.fr/hal-00877111
Notes sur l'interprétation abstraite NotesétabliesNotesétablies selon Cousot-Cousot, 1992. ,
Induction et coinduction Livre rouge. 51. Philippe Flageolet Algorithmes probabilistes sur de grandes masses de données, Chaire d'Innovation technologique -Liliane Bettencourt.Colì ege de France, 2007. ,
Constraint handling rules, Proceedings of the 8th ACM SIGPLAN symposium on Principles and practice of declarative programming , PPDP '06, pp.13-14, 2006. ,
DOI : 10.1145/1140335.1140337
OPEN : A Tool for Efficient Trace-Based Verification, Proceedings of the 11th International SPIN Workshop on Model Checking of Software, SPIN number 2989 in LNCS, pp.150-155, 2004. ,
Creating Cognitive Models from Activity Analysis : A Knowledge Engineering Approach to Car Driver Modeling, International Conference on Cognitive Modeling, pp.43-48, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01440230
Introduction to coalgebra, 2005. ,
DOI : 10.1017/CBO9781316823187
Constraint logic programming, Proceedings of the 14th ACM SIGACT-SIGPLAN symposium on Principles of programming languages , POPL '87, pp.503-581, 1994. ,
DOI : 10.1145/41625.41635
Specifying Prolog Trace Models with a Continuation Semantics, Proc. of LOgic-based Program Synthesis and TRansformation, 2000. ,
DOI : 10.1007/3-540-45142-0_10
Natural semantics, Proceedings of STACS'87, number 247 in LNCS, pp.22-39, 1987. ,
DOI : 10.1007/BFb0039592
URL : https://hal.archives-ouvertes.fr/inria-00075953
Trace générique pour CHR sur les domaines finis, 2007. ,
Uniscript, Proceedings of the the 1st ACM workshop on Continuous archival and retrieval of personal experiences , CARPE'04, 2004. ,
DOI : 10.1145/1026653.1026663
URL : https://hal.archives-ouvertes.fr/lirmm-00109204
Literate programming, CSLI, number 27 in Lecture Notes. Center for the Study of Language and Information, 1992. ,
A tracebased System Framework for Experience Management and Engineering, Second International Workshop on Experience Management and Engineering, 2006. ,
A Propagation Tracer for GNU-Prolog: From Formal Definition to Efficient Implementation, Proc. of 19th International Conference on Logic Programming, pp.269-283, 2003. ,
DOI : 10.1007/978-3-540-24599-5_19
URL : https://hal.archives-ouvertes.fr/hal-00756836
A tracer driver for hybrid execution analyses, Proceedings of the Sixth sixth international symposium on Automated analysis-driven debugging , AADEBUG'05, 2005. ,
DOI : 10.1145/1085130.1085149
A tracer driver for versatile dynamic analyses of constraint logic programs, Proceedings of the 15th Workshop on Logic-based Method for Programming Environments (WLPE'05), a pre-conference workshop of ICLP'05 Satelite event of International Conference on Logic Programming (ICLP'2005). Published in Computer Research Repository cs.SE/0508105, 2005. ,
A Generic Trace Schema for the Portability of CP(FD) Debugging Tools, Recent Advances in Constraints, number 3010 in LNAI, 2004. ,
DOI : 10.1007/978-3-540-24662-6_10
L'engrenage de la technique, essai sur une menace planétaire, 2005. ,
Foundations for the Situation Calculus, Electronic Transactions on Artificial Intelligence, vol.2, pp.159-178, 1998. ,
Observable Semantics and Dynamic Analysis of Computational Processes, 2000. ,
Semantics of Data Streams and Operators, ICDT 2005, number 3363 in LNCS, pp.37-52, 2005. ,
DOI : 10.1007/978-3-540-30570-5_3
From business rules to constraint programs in wharehouse management systems In Doctoral programme of the 13th Conference on Principles and Practice of Constraint Programming, CP'07, septembre, 2007. ,
From rules to constraint programs with the rules2cp modelling language. RR-6495, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00270326
Analyse de traces et personnalisation des environnements informatiques pour l'apprentissage humain, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01499545
Some Philosophical Problems from the Standpoint of Artificial Intelligence, Machine Intelligence, pp.463-502, 1969. ,
DOI : 10.1016/B978-0-934613-03-3.50033-7
Some Philosophical Problems from the Standpoint of Artificial Intelligence, Machine Intelligence, vol.4, pp.463-502, 1969. ,
Suivrè a la trace l'activité de deux co-acteurs : Le cas d'une rédaction conjointe médiée par un artefact numérique, 2007. ,
LISFS, Proceeding of the 28th international conference on Software engineering , ICSE '06, pp.803-806, 2006. ,
DOI : 10.1145/1134285.1134418
A Structural Approach to Operational Semantics, Journal of Logic and Algebraic Programming, pp.17-140, 1981. ,
The frame problem in the situation calculus : A simple solution (sometimes ) and a completeness result for goal regression. Artificial intelligence and mathematical theory of computation : papers in honor of John McCarthy, pp.359-380, 1991. ,
ORCAS : Towards a CHR-Based Model- Driven Framework of Reusable Reasoning Components, Proceedings of the 20th Workshop on (Constraint) Logic Programming (WLP'06), pp.192-199, 2006. ,
Constraint Programming Architectures : Review and a New Proposal, Universal Computer Science (J.UCS), vol.13, issue.6, pp.701-720, 2007. ,
Universal coalgebra: a theory of systems, Theoretical Computer Science, vol.249, issue.1, pp.3-80, 2000. ,
DOI : 10.1016/S0304-3975(00)00056-6
On streams and Coinduction, pp.3-80, 2004. ,
Abstract interpretation of small-step semantics, Proceedings of the 5th LOMAPS Workshop on Analysis and Verification of Multiple-Agent Languages, pp.76-99, 1996. ,
Les nouvelles technologies : révolution culturelle et cognitive. In L'INRIA a quarante ans. INRIA, 2007. ,
SystèmeSystèmè a base de trace pour l'apprentissage humain, 2006. ,
The Frame Problem The Macmillan Encyclopedia of Cognitive Science, pp.144-150, 2003. ,
The event calculus explained In Artificial Intelligence Today : Recent Trends and Developments, number 1600 in LNCS, 1999. ,
Coinductive Logic Programming, Lecture Notes in Computer Science, vol.4079, pp.330-345, 2006. ,
DOI : 10.1007/11799573_25
Le réseau numériquè a l'origine d'un nouveau modèle industriel. In L'INRIA a quarante ans, INRIA, 2007. ,
Introduction to the fluent calculus, Electronic Transactions on Artificial Intelligence, vol.2, pp.179-192, 1998. ,
From situation calculus to fluent calculus: State update axioms as a solution to the inferential frame problem, Artificial Intelligence, vol.111, issue.1-2, pp.277-299, 1999. ,
DOI : 10.1016/S0004-3702(99)00033-8
Automata on Infinite Objects, Handbook of Theoretical Computer Science, pp.133-191, 1990. ,
DOI : 10.1016/B978-0-444-88074-1.50009-3
Adaptive CHR Meets CHR?????????, Proceedings of the Fourth Workshop on Constraint Handling Rules, 2007. ,
DOI : 10.1080/088395100117052
Applying Webmining Techniques to Execution Traces to Support the Program Comprehension Process, Ninth European Conference on Software Maintenance and Reengineering, pp.134-142, 2005. ,
DOI : 10.1109/CSMR.2005.12
