A Survey of Distributed Garbage Collection Techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1994
Marc Shapiro
We present a protocol for the distributed detection of garbage in a distributed system subject to common failures such as lost and duplicated messages, network partition, dismounted disks, and process, site and disk crashes. The protocol uses only information local to each site, or exchanged between pairs of sites; no global mechanism is necessary. Since overhead is low, the protocol can be integrated into the operating system. We show than a logical separation of responsibility allows to integrate in the operating system the detection role leaving up to the application the collection role
Plainfosse1995.pdf (817.04 Ko) Télécharger le fichier
inria-00444635 , version 1 (05-04-2024)
Paternité
David Plainfossé, Marc Shapiro. A Survey of Distributed Garbage Collection Techniques. Second Closed BROADCAST Workshop, Broadcast Basic Research Action, 1994, Bruxelles, Belgique, Belgium. pp.211--249, ⟨10.1007/3-540-60368-9_26⟩. ⟨inria-00444635⟩
Collections
INRIA INRIA2
70 Consultations
0 Téléchargements
