Controlling Distributed Processing with Chorus Activity Messages, Proc. 18th Hawaii Conf. on Syst, 1985. ,
Amaze: a Distributed Multi- Player Game Program Using the Distributed V Kernel, Proc. 4th. Int. Conf. on Dist. Computing Syst ,
Distributed Control Through Task Migration via Abstract Networks, Proc. 5th Int. Conf. on Dist. Computing Syst ,
Implementing Remote Procedure Calls, ACM Trans. on Comp. Syst, vol.2, issue.84 ,
The V Kernel: A Software Base for Distributed Systems, IEEE Software, vol.1, issue.2 ,
DOI : 10.1109/MS.1984.234046
Distributed process groups in the V Kernel, ACM Transactions on Computer Systems, vol.3, issue.2 ,
DOI : 10.1145/214438.214439
Capability-based addressing, Communications of the ACM, vol.17, issue.7, 1974. ,
DOI : 10.1145/361011.361070
Script: a Communication Abstraction Mechanism, Proc. 2nd. ACM Symp. on Principles of Dist. Comp. (1983); reprinted in the Operating System Review ,
Smalltalk-80, the Language and its Implementation, 1983. ,
The Structure of an Operating System Mthodologie de la programmation ,
The Object Model: a Conceptual Tool for Structuring Software Operating Systems, an Advanced Course, 1979. ,
Hierarchical Process Composition in Distributed Operating Systems, Proc. 5th Int. Conf. on Dist. Computing Syst ,
Guardians and actions, Proceedings of the 9th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '82 ,
DOI : 10.1145/582153.582155
Matchmaker: a Remote Procedure Call Generator ,
Remote Procedure Call ,
Accent: a Communication-Oriented Network Operating System Kernel, Proc. 8th Symp. on Operating Syst. Principles, Asilomar Conference Grounds, 1981. ,
The Unix Time-Sharing System, Comm. A. C. M, vol.17, issue.7 ,
An Experiment in Distributed Program Design, Using Control Enrichment, Proc. 3d. Int. Conf. on Dist. Computing Syst, 1982. ,
Chorus: a Communication and Processing Architecture for Distributed Systems, 1984. ,
