On the high-SNR conditional maximum-likelihood estimator full statistical characterization
In the field of asymptotic performance characterization of the conditional maximum-likelihood (CML) estimator, asymptotic generally refers to either the number of samples or the signal-to-noise ratio (SNR) value. The first case has been already fully characterized, although the second case has been only partially investigated. Therefore, this correspondence aims to provide a sound proof of a result, i.e., asymptotic (in SNR) Gaussianity and efficiency of the CML estimator in the multiple parameters case, generally regarded as trivial but not so far demonstrated.
