A signal subspace approach to multiple emitter location and spectral estimation, 1981. ,
ESPRIT--A subspace rotation approach to estimation of parameters of cisoids in noise, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.34, issue.5, pp.1340-1342, 1986. ,
DOI : 10.1109/TASSP.1986.1164935
Estimating the Angles of Arrival of Multiple Plane Waves, IEEE Transactions on Aerospace and Electronic Systems, vol.19, issue.1, pp.134-138, 1983. ,
DOI : 10.1109/TAES.1983.309427
Sensor array processing based on subspace fitting, IEEE Transactions on Signal Processing, vol.39, issue.5, pp.1110-1121, 1991. ,
DOI : 10.1109/78.80966
Estimation of source parameters by maximum likelihood and non linear regression, Proc. IEEE Int. Conf. Acoust., Speech, Signal Processing, pp.731-734, 1984. ,
MUSIC, maximum likelihood, and Cramer-Rao bound, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.37, issue.5, pp.720-741, 1989. ,
DOI : 10.1109/29.17564
MUSIC, maximum likelihood, and Cramer-Rao bound: further results and comparisons, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.38, issue.12, pp.2140-2150, 1990. ,
DOI : 10.1109/29.61541
Estimation of spectral parameters of correlated signals in wavefields, Signal Processing, vol.11, issue.4, pp.329-337, 1986. ,
DOI : 10.1016/0165-1684(86)90075-7
Exact and Large Sample Maximum Likelihood Techniques for Parameter Estimation and Detection in Array Processing, pp.99-151, 1993. ,
DOI : 10.1007/978-3-642-77347-1_4
Theory of Point Estimation, 1983. ,
Performance study of conditional and unconditional direction-of-arrival estimation, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.38, issue.10, pp.1783-1795, 1990. ,
DOI : 10.1109/29.60109
Analysis of subspace fitting and ML techniques for parameter estimation from sensor array data, IEEE Transactions on Signal Processing, vol.40, issue.3, pp.590-599, 1992. ,
DOI : 10.1109/78.120802
On the High-SNR Conditional Maximum-Likelihood Estimator Full Statistical Characterization, IEEE Trans. on Signal Processing, 2006. ,
DOI : 10.1109/TSP.2006.882072
URL : https://hal.archives-ouvertes.fr/inria-00444708
Threshold region performance of maximum likelihood direction of arrival estimators, IEEE Transactions on Signal Processing, vol.53, issue.4, pp.1359-1373, 2005. ,
DOI : 10.1109/TSP.2005.843717
Nonefficiency of Stochastic Beamforming Bearing Estimates at High SNR and Finite Number of Samples, IEEE Signal Processing Letters, vol.11, issue.5, pp.509-512, 2004. ,
DOI : 10.1109/LSP.2004.826645
Non efficiency and non Gaussianity of a maximum likelihood estimator at high signal-to-noise ratio and finite number of samples, 2004 IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.121-124, 2004. ,
DOI : 10.1109/ICASSP.2004.1326209
URL : https://hal.archives-ouvertes.fr/halshs-00158402
Asymptotic non efficiency of a maximum likelihood estimator at finite number of samples, Proceedings EUSIPCO, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00444827
Some Classes of Global Cramer-Rao Bounds, The Annals of Statistics, vol.15, issue.4, pp.1421-1438, 1987. ,
DOI : 10.1214/aos/1176350602
Handbook of Mathematical Functions with Formulas, Graphs and Mathematical Tables, 1972. ,
An Introduction to Multivariate Statistical Analysis, 1984. ,
