Mathematical Methods of Statistics, 1946. ,
Single tone parameter estimation from discrete-time observations, IEEE Transactions on Information Theory, vol.20, issue.5, pp.591-598, 1974. ,
DOI : 10.1109/TIT.1974.1055282
Locally Best Unbiased Estimates, The Annals of Mathematical Statistics, vol.20, issue.4, pp.477-501, 1949. ,
DOI : 10.1214/aoms/1177729943
Minimum Variance Estimation Without Regularity Assumptions, The Annals of Mathematical Statistics, vol.22, issue.4, pp.581-586, 1951. ,
DOI : 10.1214/aoms/1177729548
URL : http://projecteuclid.org/download/pdf_1/euclid.aoms/1177729548
The Barankin bound and threshold behavior in frequency estimation, IEEE Transactions on Signal Processing, vol.45, issue.9, pp.2398-2401, 1997. ,
DOI : 10.1109/78.622965
A useful form of the Barankin lower bound and its application to PPM threshold analysis, IEEE Transactions on Information Theory, vol.15, issue.2, pp.273-279, 1969. ,
DOI : 10.1109/TIT.1969.1054297
Realizable lower bounds for time delay estimation. 2. Threshold phenomena, IEEE Transactions on Signal Processing, vol.42, issue.5, pp.1001-1007, 1994. ,
DOI : 10.1109/78.295217
The use of the Barankin bound for determining the threshold SNR in estimating the bearing of a source in the presence of another, 1995 International Conference on Acoustics, Speech, and Signal Processing, pp.1645-1648, 1995. ,
DOI : 10.1109/ICASSP.1995.479887
A bound on mean square estimate error, International Conference on Acoustics, Speech, and Signal Processing, pp.1675-1680, 1993. ,
DOI : 10.1109/ICASSP.1990.115630
On some analogues of the amount of information and their use in statistical estimation, Sankhya Indian J. Stat, vol.8, pp.1-14, 1946. ,
On the true Cramer Rao lower bound for the DA joint estimation of carrier phase and timing offsets, Proc. IEEE Int. Conf. Commun, pp.331-335, 2000. ,
SNR Threshold Indicator in Data-Aided Frequency Synchronization, IEEE Signal Processing Letters, vol.11, issue.8, pp.652-654, 2004. ,
DOI : 10.1109/LSP.2004.831683
Theory of Point Estimation, 1983. ,
A new look at the Barankin lower bound, IEEE Transactions on Information Theory, vol.18, issue.3, pp.349-356, 1972. ,
DOI : 10.1109/TIT.1972.1054810
On lower bounds for deterministic parameter estimation, " presented at the IEEE Int, Conf. Acoust., Speech, Signal Process, 2002. ,
Bayesian Bounds for Matched-Field Parameter Estimation, IEEE Transactions on Signal Processing, vol.52, issue.12, pp.3293-3305, 2004. ,
DOI : 10.1109/TSP.2004.837437
A Barankin-type lower bound on the estimation error of a hybrid parameter vector, IEEE Transactions on Information Theory, vol.43, issue.3, pp.1084-1093, 1997. ,
DOI : 10.1109/18.568725
Barankin bounds for source localization in an uncertain ocean environment, IEEE Transactions on Signal Processing, vol.47, issue.11, pp.2917-2927, 1999. ,
DOI : 10.1109/78.796428
Performances bounds on matched-field methods for source localization and estimation of ocean environmental parameters, Dept. Ocean Eng., Massachusetts Inst. Technol, 2001. ,
DOI : 10.1575/1912/3477
