Maximum-likelihood from incomplete data via the EM algorithm, J. Roy. Stat. Soc, vol.39, issue.1, pp.1-38, 1977. ,
The EM Algorithm and Extensions, 1997. ,
On Convergence Properties of the EM Algorithm for Gaussian Mixtures, Neural Computation, vol.11, issue.1, pp.129-151, 1996. ,
DOI : 10.1162/neco.1994.6.2.334
On the Convergence of Bound Optimization Algorithms ,
Prediction of the EM-Algorithm Speed of Convergence with Cramer-Rao Bounds, 2007 IEEE International Conference on Acoustics, Speech and Signal Processing, ICASSP '07, 2007. ,
DOI : 10.1109/ICASSP.2007.366802
The modified Cramer-Rao bound and its application to synchronization problems, IEEE Trans. Commun, vol.424, issue.23, pp.1391-1399, 1994. ,
The Cramer-Rao bound for phase estimation from coded linearly modulated signals, IEEE Communications Letters, vol.7, issue.5, pp.207-209, 2003. ,
DOI : 10.1109/LCOMM.2003.812168
On the true and the modified Cramer-Rao bounds for the estimation of a scalar parameter in the presence of nuisance parameters, IEEE Transactions on Communications, vol.46, issue.11, pp.1536-1544, 1998. ,
DOI : 10.1109/26.729398
On the Convergence Properties of the EM Algorithm, The Annals of Statistics, vol.11, issue.1, pp.95-103, 1983. ,
DOI : 10.1214/aos/1176346060
Turbo-synchronization: An EM algorithm approach, Proc. IEEE Int. Conf. Commun. (ICC), pp.2933-2937, 2003. ,
Phase and frequency estimation for PSK packets: bounds and algorithms, IEEE Transactions on Communications, vol.44, issue.1, pp.26-28, 1996. ,
DOI : 10.1109/26.476092
Nonlinear estimation of PSK-modulated carrier phase with application to burst digital transmission, IEEE Transactions on Information Theory, vol.29, issue.4, pp.543-551, 1983. ,
DOI : 10.1109/TIT.1983.1056713
Fundamentals of Statistical Signal Processing: Estimation Theory, 1993. ,
