A. Renaux, P. Forster, and P. Larzabal, A new derivation of the bayesian bounds for parameter estimation, IEEE/SP 13th Workshop on Statistical Signal Processing, 2005, pp.567-572, 2005.
DOI : 10.1109/SSP.2005.1628659
URL : https://hal.archives-ouvertes.fr/inria-00444830
A. Renaux, P. Forster, P. Larzabal, and C. Richmond, The Bayesian ABEL Bound on the Mean Square Error, 2006 IEEE International Conference on Acoustics Speed and Signal Processing Proceedings, pp.9-12, 2006.
DOI : 10.1109/ICASSP.2006.1660577
URL : https://hal.archives-ouvertes.fr/halshs-00158377
R. A. Fisher, On the Mathematical Foundations of Theoretical Statistics, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.222, issue.594-604, p.309, 1922.
DOI : 10.1098/rsta.1922.0009
D. Dugué, Application des propriétés de la limite au sens du calcul des probabilités à I'étude des diverses questions d'estimation, Ecol. Poly, vol.3, pp.305-372, 1937.
M. Frechet, Sur l'extension de certaines evaluations statistiques au cas de petits echantillons, Revue de l'Institut International de Statistique / Review of the International Statistical Institute, vol.11, issue.3/4, pp.182-205, 1943.
DOI : 10.2307/1401114
G. Darmois, Sur les limites de la dispersion de certaines estimations, Revue de l'Institut International de Statistique / Review of the International Statistical Institute, vol.13, issue.1/4, pp.9-15, 1945.
DOI : 10.2307/1400974
C. R. Rao, Information and the Accuracy Attainable in the Estimation of Statistical Parameters, Bull. Calcutta Math. Soc, vol.37, pp.81-91, 1945.
DOI : 10.1007/978-1-4612-0919-5_16
H. Cramér, Mathematical Methods of Statistics, 1946.
L. L. Scharf and T. Mcwhorter, Geometry of the Cramer-Rao bound, Signal Processing, vol.31, issue.3, pp.301-311, 1993.
DOI : 10.1016/0165-1684(93)90088-R
J. Xavier and V. Barroso, The Riemannian geometry of certain parameter estimation problems with singular Fisher information matrices, 2004 IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.1021-1024, 2004.
DOI : 10.1109/ICASSP.2004.1326434
J. Xavier and V. Barroso, Intrinsic Variance Lower Bound (IVLB): An Extension of the Cramer-Rao Bound to Riemannian Manifolds, Proceedings. (ICASSP '05). IEEE International Conference on Acoustics, Speech, and Signal Processing, 2005., pp.1033-1036, 2004.
DOI : 10.1109/ICASSP.2005.1416483
A. Manikas, Differential Geometry in Array Processing, 2004.
DOI : 10.1142/p309
S. T. Smith, Statistical resolution limits and the complexified Crame/spl acute/r-Rao bound, IEEE Transactions on Signal Processing, vol.53, issue.5, pp.1597-1609, 2005.
DOI : 10.1109/TSP.2005.845426
S. T. Smith, Covariance, subspace, and intrinsic Crame/spl acute/r-Rao bounds, IEEE Transactions on Signal Processing, vol.53, issue.5, pp.1610-1630, 2005.
DOI : 10.1109/TSP.2005.845428
J. Delmas and H. Abeida, Stochastic Cram??r???Rao Bound for Noncircular Signals with Application to DOA Estimation, IEEE Transactions on Signal Processing, vol.52, issue.11, pp.3192-3199, 2004.
DOI : 10.1109/TSP.2004.836462
J. Delmas and H. Abeida, Cramer-Rao bounds of DOA estimates for BPSK and QPSK Modulated signals, IEEE Transactions on Signal Processing, vol.54, issue.1, pp.117-126, 2005.
DOI : 10.1109/TSP.2005.859224
E. Chaumette, P. Larzabal, and P. Forster, On the influence of a detection step on lower bounds for deterministic parameter estimation, IEEE Transactions on Signal Processing, vol.53, issue.11, pp.4080-4090, 2005.
DOI : 10.1109/TSP.2005.857027
URL : https://hal.archives-ouvertes.fr/halshs-00158304
Q. Zou, Z. Lin, and R. J. Ober, The Cramer Rao lower bound for bilinear systems, IEEE Trans. Signal Process, vol.54, pp.1666-1680, 2006.
I. Yetik and A. Nehorai, Performance bounds on image registration, IEEE Transactions on Signal Processing, vol.54, issue.5, pp.1737-1736, 2006.
DOI : 10.1109/TSP.2006.870552
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.332.1237
D. C. Rife and R. R. Boorstyn, Single tone parameter estimation from discrete-time observations, IEEE Transactions on Information Theory, vol.20, issue.5, pp.591-598, 1974.
DOI : 10.1109/TIT.1974.1055282
A. Bhattacharyya, On some analogues of the amount of information and their use in statistical estimation, Sankhya Indian J. Statist, vol.8, pp.1-14, 1946.
D. A. Fraser and I. Guttman, Bhattacharyya Bounds without Regularity Assumptions, The Annals of Mathematical Statistics, vol.23, issue.4, pp.629-632, 1952.
DOI : 10.1214/aoms/1177729344
D. G. Chapman and H. Robbins, Minimum Variance Estimation Without Regularity Assumptions, The Annals of Mathematical Statistics, vol.22, issue.4, pp.581-586, 1951.
DOI : 10.1214/aoms/1177729548
URL : http://projecteuclid.org/download/pdf_1/euclid.aoms/1177729548
J. Kiefer, On Minimum Variance Estimators, The Annals of Mathematical Statistics, vol.23, issue.4, pp.627-629, 1952.
DOI : 10.1214/aoms/1177729343
J. M. Hammersley, On estimating restricted parametrers, J. Royal Soc. Ser. B, vol.12, pp.192-240, 1950.
E. W. Barankin, Locally Best Unbiased Estimates, The Annals of Mathematical Statistics, vol.20, issue.4, pp.477-501, 1949.
DOI : 10.1214/aoms/1177729943
R. J. Mcaulay, L. P. Seidman, and J. S. Abel, A useful form of the Barankin lower bound and its application to ppm threshold analysis A bound on mean square estimate error, Proc. IEEE Int, pp.273-279, 1969.
J. S. Abel, A bound on mean square estimate error, International Conference on Acoustics, Speech, and Signal Processing, pp.1675-1680, 1993.
DOI : 10.1109/ICASSP.1990.115630
R. J. Mcaulay and E. M. Hofstetter, Barankin Bounds on Parameter Estimation, IEEE Transactions on Information Theory, vol.17, issue.6, pp.669-676, 1971.
DOI : 10.1109/TIT.1971.1054719
A. Quinlan, E. Chaumette, and P. Larzabal, A Direct Method to Generate Approximations of the Barankin Bound, 2006 IEEE International Conference on Acoustics Speed and Signal Processing Proceedings, pp.808-811, 2006.
DOI : 10.1109/ICASSP.2006.1660777
J. Ziv and M. Zakai, Some lower bounds on signal parameter estimation, IEEE Transactions on Information Theory, vol.15, issue.3, pp.386-391, 1969.
DOI : 10.1109/TIT.1969.1054301
S. Bellini and G. Tartara, Bounds on Error in Signal Parameter Estimation, IEEE Transactions on Communications, vol.22, issue.3, pp.340-342, 1974.
DOI : 10.1109/TCOM.1974.1092192
D. Chazan, M. Zakai, and J. Ziv, Improved Lower Bounds on Signal Parameter Estimation, IEEE Transactions on Information Theory, vol.21, issue.1, pp.90-93, 1975.
DOI : 10.1109/TIT.1975.1055325
E. Weinstein, Relations between Belini-Tartara, Chazan-Zakai-Ziv, and Wax-Ziv lower bounds, IEEE Transactions on Information Theory, vol.34, issue.2, pp.342-343, 1988.
DOI : 10.1109/18.2648
K. L. Bell, Y. Steinberg, Y. Ephraim, and H. L. Trees, Extended Ziv-Zakai lower bound for vector parameter estimation, IEEE Transactions on Information Theory, vol.43, issue.2, pp.624-638, 1997.
DOI : 10.1109/18.556118
K. L. Bell, Performance bounds in parameter estimation with application to bearing estimation, 1995.
B. Z. Bobrovsky, E. Mayer-wolf, and M. Zakai, Some Classes of Global Cramer-Rao Bounds, The Annals of Statistics, vol.15, issue.4, pp.1421-1438, 1987.
DOI : 10.1214/aos/1176350602
B. Z. Bobrovsky and M. Zakai, A lower bound on the estimation error for certain diffusion processes, IEEE Transactions on Information Theory, vol.22, issue.1, pp.45-52, 1976.
DOI : 10.1109/TIT.1976.1055513
I. Reuven and H. Messer, A Barankin-type lower bound on the estimation error of a hybrid parameter vector, IEEE Transactions on Information Theory, vol.43, issue.3, pp.1084-1093, 1997.
DOI : 10.1109/18.568725
A. J. Weiss and E. Weinstein, A lower bound on the mean-square error in random parameter estimation (Corresp.), IEEE Transactions on Information Theory, vol.31, issue.5, pp.680-682, 1985.
DOI : 10.1109/TIT.1985.1057094
H. L. Van-trees and K. L. Bell, Bayesian Bounds for Parameter Estimation and Nonlinear Filtering/Tracking, 2007.
DOI : 10.1109/9780470544198
A. B. Baggeroer, Barankin Bound on the Variance of Estimates of Gaussian Random Process MIT Lincoln Lab, 1969.
I. Reuven and H. Messer, The use of the Barankin bound for determining the threshold SNR in estimating the bearing of a source in the presence of another, 1995 International Conference on Acoustics, Speech, and Signal Processing, pp.1645-1648, 1995.
DOI : 10.1109/ICASSP.1995.479887
L. Knockaert, The Barankin bound and threshold behavior in frequency estimation, IEEE Transactions on Signal Processing, vol.45, issue.9, pp.2398-2401, 1997.
DOI : 10.1109/78.622965
J. Tabrikian and J. L. Krolik, Barankin bound for source localization in shallow water, 1997 IEEE International Conference on Acoustics, Speech, and Signal Processing, 1997.
DOI : 10.1109/ICASSP.1997.599684
T. L. Marzetta, Computing the Barankin bound, by solving an unconstrained quadratic optimization problem, 1997 IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.3829-3832, 1997.
DOI : 10.1109/ICASSP.1997.604717
I. Reuven and H. Messer, On the effect of nuisance parameters on the threshold SNR value of the Barankin bound, IEEE Transactions on Signal Processing, vol.47, issue.2, pp.523-527, 1999.
DOI : 10.1109/78.740136
J. Tabrikian and J. Krolik, Barankin bounds for source localization in an uncertain ocean environment, IEEE Transactions on Signal Processing, vol.47, issue.11, pp.2917-2927, 1999.
DOI : 10.1109/78.796428
A. Ferrari and J. Tourneret, Barankin lower bound for change-points in independent sequences, IEEE Workshop on Statistical Signal Processing, 2003, pp.557-560, 2003.
DOI : 10.1109/SSP.2003.1289526
URL : https://hal.archives-ouvertes.fr/hal-00376422
P. Ciblat, M. Ghogho, P. Forster, and P. Larzabal, Harmonic retrieval in the presence of non-circular Gaussian multiplicative noise: performance bounds, Signal Processing, vol.85, issue.4, pp.737-749, 2005.
DOI : 10.1016/j.sigpro.2004.11.015
P. Ciblat, P. Forster, and P. Larzabal, Harmonic retrieval in noncircular complex-valued multiplicative noise: Barankin bound, Proc. EUS1PCO, pp.2151-2154, 2004.
L. Atallah, J. P. Barbot, and P. Larzabal, SNR Threshold Indicator in Data-Aided Frequency Synchronization, IEEE Signal Processing Letters, vol.11, issue.8, pp.652-654, 2004.
DOI : 10.1109/LSP.2004.831683
L. Atallah, J. P. Barbot, and P. Larzabal, From Chapman-Robbins bound towards Barankin bound in threshold behaviour prediction, Electronics Letters, vol.40, issue.4, pp.279-280, 2004.
DOI : 10.1049/el:20040152
A. Renaux, L. N. Atallah, P. Forster, and P. Larzabal, A Useful Form of the Abel Bound and Its Application to Estimator Threshold Prediction, IEEE Transactions on Signal Processing, vol.55, issue.5, pp.2365-2369, 2007.
DOI : 10.1109/TSP.2006.890928
URL : https://hal.archives-ouvertes.fr/inria-00444722
W. Xu, Performances bounds on matched-field methods for source localization and estimation of ocean environmental parameters, Mass. Inst. Technol, 2001.
DOI : 10.1575/1912/3477
W. Xu, A. B. Baggeroer, and K. Bell, A Bound on Mean-Square Estimation Error With Background Parameter Mismatch, IEEE Transactions on Information Theory, vol.50, issue.4, pp.621-632, 2004.
DOI : 10.1109/TIT.2004.825023
W. Xu, A. B. Baggeroer, and C. D. Richmond, Bayesian Bounds for Matched-Field Parameter Estimation, IEEE Transactions on Signal Processing, vol.52, issue.12, pp.3293-3305, 2004.
DOI : 10.1109/TSP.2004.837437
A. J. Weiss and E. Weinstein, Fundamental limitations in passive time delay estimation--Part I: Narrow-band systems, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.31, issue.2, pp.472-486, 1983.
DOI : 10.1109/TASSP.1983.1164061
K. L. Bell, Y. Ephraim, and H. L. Trees, Ziv Zakai lower bounds in bearing estimation, Proc. IEEE Int, pp.2852-2855, 1995.
K. L. Bell, Y. Ephraim, and H. L. Trees, Explicit Ziv-Zakai lower bound for bearing estimation, IEEE Transactions on Signal Processing, vol.44, issue.11, pp.2810-2824, 1996.
DOI : 10.1109/78.542439
P. Ciblat and M. Ghogho, ZIV-ZAKAI bound for harmonic retrieval in multiplicative and additive gaussian noise, IEEE/SP 13th Workshop on Statistical Signal Processing, 2005, pp.561-566, 2005.
DOI : 10.1109/SSP.2005.1628658
A. Renaux, Weiss–Weinstein Bound for Data-Aided Carrier Estimation, IEEE Signal Processing Letters, vol.14, issue.4, pp.283-286, 2007.
DOI : 10.1109/LSP.2006.887782
F. E. Glave, A new look at the Barankin lower bound, IEEE Transactions on Information Theory, vol.18, issue.3, pp.349-356, 1972.
DOI : 10.1109/TIT.1972.1054810
P. Forster and P. Larzabal, On lower bounds for deterministic parameter estimation, Proc, pp.1137-1140, 2002.
E. Weinstein and A. J. Weiss, A general class of lower bounds in parameter estimation, IEEE Transactions on Information Theory, vol.34, issue.2, pp.338-342, 1988.
DOI : 10.1109/18.2647
S. M. Kay, Fundamentals of Statistical Signal Processing, 1993.
A. Renaux, Contribution a panalyse des performances d'estimaiion en traitement statisticue du signal " Ph.D. dissertation, Ecole Normale Superieure de Cachan, 2006.
S. Gradshteyn and I. M. Ryzhik, Table of Integrals, Series, and Products, 1994.
