Lazy Consistency Using Loosely Synchronized Clocks, 16th Symp. on Princ. of Distr. Comp. (PODC), pp.73-82, 1997. ,
Epidemic algorithms in replicated databases, 16th Symp. on Princ. of Database Sys. (PODS), pp.161-172, 1997. ,
). O'Reilly & Associates, DNS and BIND, 2001. ,
Panasync: Dependency tracking among file copies, 9th ACM SIGOPS European Workshop, pp.7-12, 2000. ,
Version stamps ? decentralized version vectors, 22nd Int. Conf. on Dist. Comp. Sys. (ICDCS), pp.544-551, 2002. ,
Data caching issues in an information retrieval system, ACM Trans. on Database Sys. (TODS), vol.15, issue.3, pp.359-384, 1990. ,
Measurements of a distributed file system, 13th Symp. on Op. Sys. Principles (SOSP), pp.198-212, 1991. ,
What is a File Synchronizer, Int. Conf. on Mobile Comp. and Netw. (MobiCom '98), 1998. ,
The failure and recovery problem for replicated databases, Proceedings of the second annual ACM symposium on Principles of distributed computing , PODC '83, pp.114-122, 1983. ,
DOI : 10.1145/800221.806714
Concurrency Control and Recovery in Database Systems Available online from http, 1987. ,
Reliable communication in the presence of failures, ACM Trans. on Comp. Sys. (TOCS), vol.5, issue.1, pp.272-314, 1987. ,
Grapevine: An exercise in distributed computing, Comm. of the ACM, vol.25, issue.4, pp.260-274, 1982. ,
Applying RCS and SCCS, 1995. ,
Khazana: An infrastructure for building distributed services, 18th Int. Conf. on Dist. Comp. Sys. (ICDCS), pp.562-571, 1998. ,
Version management with CVS, 2001. ,
End-to-end WAN service availability, 3rd USENIX Symp. on Internet Tech. and Sys. (USITS), 2001. ,
DOI : 10.1109/tnet.2003.810312
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.19.7921
Unreliable Failure Detectors for Reliable Distributed Systems, Journal of the ACM, vol.43, issue.2, pp.225-267, 1996. ,
A Hierarchical Internet Object Cache, pp.153-164, 1996. ,
A prototype implementation of archival intermemory, Fourth ACM Conf. on Digital Libraries (DL'99), pp.28-37, 1999. ,
Synchronizing a database to improve freshness, Int. Conf. on Management of Data (SIGMOD), pp.117-128, 2000. ,
Fast reconciliations in fluid replication, 21st Int. Conf. on Dist. Comp. Sys. (ICDCS), 2001. ,
Plausible clocks: constant size logical clocks for distributed systems, 10th Int. Workshop on Dist. Algorithms (WDAG), 1996. ,
Multicast Routing in a Datagram Internetwork Epidemic algorithms for replicated database maintenance, 6th Symp. on Princ. of Distr. Comp. (PODC), pp.1-12, 1987. ,
Concurrency Control in Groupware Systems, Int. Conf. on Management of Data (SIGMOD), 1989. ,
Database Transaction Models for Advanced Applications, 1992. ,
Eventually serializable data services, Theoretical Computer Science, vol.220, pp.113-156, 1999. ,
Specifying and using a partitionable group communication service, 16th Symp. on Princ. of Distr. Comp. (PODC), pp.53-62, 1997. ,
RFC2616: Hypertext transfer protocol ? HTTP/1.1, 1999. ,
Impossibility of distributed consensus with one faulty process, Journal of the ACM, vol.32, issue.2, pp.374-382, 1985. ,
Sacrificing serializability to attain availability of data in an unreliable network, 1st Symp. on Princ. of Database Sys. (PODS), pp.70-75, 1982. ,
A Reliable Multicast Framework for Light-weight Sessions and Application Level Framing, IEEE/ACM Journal on Networking, vol.5, issue.6, pp.784-803, 1997. ,
Harvest, Yield, and Scalable Tolerant Systems, 6th Workshop on Hot Topics in Operating Systems (HOTOS-VI), pp.174-178, 1999. ,
Dangers of replication and a solution, Int. Conf. on Management of Data (SIGMOD), pp.173-182, 1996. ,
Transaction Processing: Concepts and Techniques, 1993. ,
Consistency algorithms for optimistic replication, Proc. First IEEE Int. Conf. on Network Protocols, 1993. ,
A survey of gossiping and broadcasting in communication networks, pp.319-349, 1988. ,
Scalable Versioning in Distributed Databases with Commuting Updates, 13th Int. Conf. on Data Eng. (ICDE), pp.520-531, 1997. ,
RFC677: The maintenance of duplicate databases, 1976. ,
Hierarchical matrix timestamps for scalable update propagation, 1996. ,
The hash history approach for reconciling mutual inconsistency, 23rd Int. Conf. on Dist. Comp. Sys. (ICDCS), 2003. ,
RFC977: Network news transfer protocol, 1986. ,
Replicated document management in a group communication system, Conf. on Comp.- Supported Coop. Work (CSCW) (Chapel Hill, 1988. ,
Spatial gossip and resource location protocols, 33rd Symp. on Theory of Computing (STOC), 2001. ,
The Ice- Cube approach to the reconciliation of diverging replicas, 20th Symp. on Princ. of Distr. Comp. (PODC), 2001. ,
Safety, visibility, and performance in a wide-area file system Usenix, USENIX Conf. on File and Storage Technologies (FAST), 2002. ,
Disconnected operation in the Coda file system, ACM Trans. on Comp. Sys. (TOCS), vol.10, issue.5, pp.3-25, 1992. ,
Bounded Ignorance: A Technique for Increasing Concurrency in Replicated Systems, ACM Trans. on Database Sys. (TODS), vol.19, issue.4, pp.685-722, 1994. ,
Semantic based transaction management techniques for replicated data, Int. Conf. on Management of Data (SIGMOD), pp.117-125, 1988. ,
An analysis of borrowing policies for escrow transactions in a replicated environment, 6th Int. Conf. on Data Eng. (ICDE), pp.446-454, 1990. ,
Log-based Directory Resolution in the Coda File System, 2nd Int. Conf. on Parallel and Dist. Info. Sys. (PDIS), pp.202-213, 1993. ,
Flexible and safe resolution of file conflicts, USENIX Winter Tech. Conf, pp.95-106, 1995. ,
Lazy replication: exploiting the semantics of distributed services, MIT, 1990. ,
Providing high availability using lazy replication, ACM Trans. on Comp. Sys. (TOCS), vol.10, issue.4, pp.360-391, 1992. ,
Optimising synchronisation times for mobile devices, Advances in Neural Information Processing Systems, pp.1401-1408, 2002. ,
Operation shipping for mobile file systems, IEEE Trans. on Computers, vol.51, pp.1410-1422, 2002. ,
Drinking from the Firehose: Multicast USENET News, USENIX Winter Tech. Conf, pp.33-45, 1994. ,
Directional gossip: Gossip in a wide-area network, Third European Dependable Computing Conference, pp.364-379, 1999. ,
Improving data consistency in mobile computing using isolation-only transactions, 4th Workshop on Hot Topics in Operating Systems (HOTOS-IV) (Orcas Island, 1995. ,
Building secure file systems out of Byzantine storage, 21st Symp. on Princ. of Distr. Comp. (PODC), 2002. ,
Set reconciliation with nearly optimal communication complexity, International Symposium on Information Theory, 2001. ,
Implementing fault-tolerant replicated objects using Psync, 8th Symp. on Reliable Dist. Sys. (SRDS), pp.42-53, 1989. ,
Development of the Domain Name System, ACM SIGCOMM, pp.123-133, 1988. ,
Safe Generic Data Synchronizer, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00107740
Exploiting weak connectivity for mobile file access, 15th Symp. on Op. Sys. Principles (SOSP) (Copper, pp.143-155, 1995. ,
A low-bandwidth network file system, 18th Symp. on Op. Sys. Principles (SOSP), pp.174-187, 2001. ,
A trace-driven analysis of the Unix 4.2 BSD file system, 10th Symp. on Op. Sys. Principles (SOSP), pp.15-24, 1985. ,
Operation transforms for a distributed shared spreadsheet, Conf. on Comp.-Supported Coop. Work (CSCW), pp.69-78, 1998. ,
Detection of mutual inconsistency in distributed systems, IEEE Trans. on Software Engineering SE, vol.3, issue.9, pp.240-247, 1983. ,
Reliable multicast transport protocol (RMTP), IEEE Journal on Selected Areas in Communications, vol.15, issue.3, pp.407-421, 1997. ,
Flexible Update Propagation for Weakly Consistent Replication, 16th Symp. on Op. Sys. Principles (SOSP), pp.288-301, 1997. ,
Semantics-based reconciliation for collaborative and environments, Proc. Tenth Int. Conf. on Cooperative Information Systems (CoopIS), 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00445758
Divergence control for distributed database systems, Distributed and Parallel Databases, vol.3, issue.1, pp.85-109, 1995. ,
Replica Control in Distributed Systems: An Asynchronous Approach, Int. Conf. on Management of Data (SIGMOD), pp.377-386, 1991. ,
Efficient Update Propagation in Epidemic Replicated Databases, Int. Conf. on Extending Database Technology (EDBT) ¢ Saito and Shapiro, pp.207-222, 1996. ,
Executive Briefing: Advances in Concurrency Control and Transaction Processing, 1996. ,
A formal characterization of epsilon serializability, IEEE Trans. on Knowledge and Data Eng, vol.7, issue.6, pp.997-1007, 1995. ,
An Algebraic Approach to File Synchronization, 9th Int. Symp. on the Foundations of Softw. Eng. (FSE) (Austria, 2001. ,
Dynamic version vector maintenance, 1997. ,
Resolving File Conflicts in the Ficus File System, USENIX Summer Tech. Conf, pp.183-195, 1994. ,
Palm Programming: The Developer's Guide, 1998. ,
Optimistic Replication for Internet Data Services, 14th Int. Conf. on Dist. Computing (DISC), pp.297-314, 2000. ,
DOI : 10.1007/3-540-40026-5_20
A Usenet performance study, 1998. ,
Managing Usenet. O'Reilly & Associates, 1998. ,
Dealing with server corruption in weakly consistent, replicated data systems, 3rd Int. Conf. on Mobile Computing and Networking (MOBICOM), 1997. ,
A Protocol-Independent Technique for Eliminating Redundant Network Traffic, In ACM SIGCOMM, 2000. ,
Operational transformation in real-time group editors: issues, algorithms, and achievements, Conf. on Comp.-Supported Coop. Work (CSCW), pp.59-68, 1998. ,
Achieving convergence, causality-preservation, and intention-preservation in real-time cooperative editing systems, ACM Transactions on Computer-Human Interaction, vol.5, issue.1, pp.63-108, 1998. ,
A consistency model and supporting schemes for real-time cooperative editing systems, 19th Australian Computer Science Conference, pp.582-591, 1996. ,
Reliable multicast for publish/subscribe systems, 1998. ,
Session Guarantees for Weakly Consistent Replicated Data, 3rd Int. Conf. on Parallel and Dist. Info. Sys. (PDIS), pp.140-149, 1994. ,
An examination of conflicts in a weakly-consistent, replicated application, 2000. ,
Managing update conflicts in Bayou, a weakly connected replicated storage system, 15th Symp. on Op. Sys. Principles (SOSP) (Copper, pp.172-183, 1995. ,
Copies convergence in a distributed real-time collaborative environment, Conf. on Comp.-Supported Coop. Work (CSCW), pp.171-180, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00684563
The LOCUS distributed operating system, 9th Symp. on Op. Sys. Principles (SOSP), pp.49-70, 1983. ,
Understanding the conflict rate metric for peer optimistically replicated filing environments, 2001. ,
RFC2186: Internet Cache Protocol, 1997. ,
Efficient solutions to the replicated log and dictionary problems, 3rd Symp. on Princ. of Distr. Comp. (PODC), pp.233-242, 1984. ,
Hierarchical cache consistency in a WAN, 2nd USENIX Symp. on Internet Tech. and Sys. (USITS), pp.13-24, 1999. ,
Design and Evaluation of a Continuous Consistency Model for Replicated Services, 4th Symp. on Op. Sys. Design and Impl. (OSDI), pp.305-318, 2000. ,
The Costs and Limits of Availability for Replicated Services, 18th Symp. on Op. Sys. Principles (SOSP), pp.29-42, 2001. ,
Minimal replication cost for availability, 21st Symp. on Princ. of Distr. Comp. (PODC), pp.98-107, 2002. ,
The stationarity of Internet path properties: routing, loss and throughput, 2000. ,
