Scaling Optimistic Replication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Replication improves the performance and availability of sharing information in a largescale network. Classical, pessimistic replication incurs network access before any access, in order to avoid conflicts and resulting stale reads and lost writes. Pessimistic protocols assume some central locking site or necessitate distributed consensus. The protocols are fragile in the presence of network failures, partitioning, or denial-of-service attacks. They are safe (i.e., stale reads and lost writes do not occur) but at the expense of performance and availability, and they do not scale well.
Mots clés
rep
Fichier non déposé
inria-00444780 , version 1 (07-01-2010)
  • HAL Id : inria-00444780 , version 1
Marc Shapiro, Yasushi Saito. Scaling Optimistic Replication. Worskshop on Future Directions in Distributed Computing (FuDiCo 2002): Research and Position Papers, 2002, Bertinoro, Forlì, Italy, Italy. pp.164--168. ⟨inria-00444780⟩
83 Consultations
0 Téléchargements
