Detection, Estimation and Modulation Theory, 1968. ,
Multiple emitter location and signal parameter estimation, IEEE Transactions on Antennas and Propagation, vol.34, issue.3, pp.276-280, 1986. ,
DOI : 10.1109/TAP.1986.1143830
Two decades of array signal processing research: the parametric approach, IEEE Signal Processing Magazine, vol.13, issue.4, pp.67-94, 1996. ,
DOI : 10.1109/79.526899
A sequential estimation approach for performance improvement of eigenstructure-based methods in array processing, IEEE Trans. on Signal Processing, vol.41, pp.457-463, 1993. ,
Improved sequential MUSIC, IEEE Transactions on Aerospace and Electronic Systems, vol.31, issue.4, pp.1230-1239, 1995. ,
DOI : 10.1109/7.464347
Recursive MUSIC: A framework for EEG and MEG source localization, IEEE Transactions on Biomedical Engineering, vol.45, issue.11, pp.1342-1354, 1998. ,
DOI : 10.1109/10.725331
Source localization using recursively applied and projected (RAP) MUSIC, IEEE Transactions on Signal Processing, vol.47, issue.2, pp.332-340, 1999. ,
DOI : 10.1109/78.740118
URL : http://digital.library.unt.edu/ark:/67531/metadc690712/m2/1/high_res_d/642821.pdf
Spectral Analysis of Signals, 2005. ,
Zero location with respect to the unit circle of discrete-time linear system polynomials, Proc. of the IEEE, pp.1131-1142, 1984. ,
DOI : 10.1109/PROC.1984.12993
An Explicit Jordan Decomposition of Companion Matrices, TEMA - Tend??ncias em Matem??tica Aplicada e Computacional, vol.7, issue.2, pp.209-218, 2006. ,
DOI : 10.5540/tema.2006.07.02.0209
