The Cramer-Rao bound on frequency estimates of signals closely spaced in frequency, IEEE Transactions on Signal Processing, vol.40, issue.6, pp.1507-1517, 1992. ,
DOI : 10.1109/78.139253
Statistical resolution limits and the complexified Crame/spl acute/r-Rao bound, IEEE Transactions on Signal Processing, vol.53, issue.5, pp.1597-1609, 2005. ,
DOI : 10.1109/TSP.2005.845426
Fundamental Limitations on the Resolution of Deterministic Signals, IEEE Transactions on Signal Processing, vol.56, issue.11, pp.5309-5318, 2008. ,
DOI : 10.1109/TSP.2008.929654
Nonmatrix Cramer-Rao bound expressions for high-resolution frequency estimators, IEEE Transactions on Signal Processing, vol.46, issue.2, pp.463-474, 1998. ,
DOI : 10.1109/78.655430
Frequency Estimation for Closely Spaced Sinsoids: Simple Approximations to the Cramer-Rao Lower Bound, IEEE Transactions on Signal Processing, vol.41, issue.1, pp.489-495, 1993. ,
DOI : 10.1109/TSP.1993.193185
Statistical Resolution Limits of DOA for Discrete Sources, 2006 IEEE International Conference on Acoustics Speed and Signal Processing Proceedings, pp.889-892, 2006. ,
DOI : 10.1109/ICASSP.2006.1661112
A weighted linear prediction method for near-field source localization, IEEE Transactions on Signal Processing, vol.53, issue.10, pp.3651-3660, 2005. ,
DOI : 10.1109/TSP.2005.855100
Efficient direction and polarization estimation with a cold array, IEEE Trans. Antennas Propagat, vol.44, issue.4, pp.539-547, 1996. ,
Application of antenna arrays to mobile communications. II. Beam-forming and direction-of-arrival considerations, Proceedings of the IEEE, vol.85, issue.8, pp.1195-1245, 1997. ,
DOI : 10.1109/5.622504
Mathematical Methods of Statistics, 1946. ,
Fundamentals of Statistical Signal Processing, NJ, vol.1, 1993. ,
Nonmatrix closed-form expressions of the Cramér-Rao bounds for near-field localization parameters, Proc. IEEE Int. Conf. Acoust., Speech, Signal Processing, pp.3277-3280, 2009. ,
