Integrated Modulo Scheduling for Clustered VLIW Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We solve the problem of integrating modulo scheduling with instruction selection (including cluster assignment), instruction scheduling and register allocation, with optimal spill code generation and scheduling. Ourmethod is based on integer linear programming.We prove that our algorithm delivers optimal results in finite time for a certain class of architectures. We believe that these results are interesting both from a theoretical point of view and as a reference point when devising heuristicmethods.
inria-00445475 , version 1 (08-01-2010)
Mattias V. Eriksson, Christoph W. Kessler. Integrated Modulo Scheduling for Clustered VLIW Architectures. HiPEAC 2009 - High Performance and Embedded Architectures and Compilers, Jan 2009, Paphos, Cyprus. ⟨10.1007/978-3-540-92990-1_7⟩. ⟨inria-00445475⟩
Collections
HIPEAC09
11 Consultations
0 Téléchargements
