ACM: An Efficient Approach for Managing Shared Caches in Chip Multiprocessors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper proposes and studies a hardware-based adaptive controlled migration strategy for managing distributed L2 caches in chip multiprocessors. Building on an area-efficient shared cache design, the proposed scheme dynamically migrates cache blocks to cache banks that best minimize the average L2 access latency. Cache blocks are continuously monitored and the locations of the optimal corresponding cache banks are predicted to effectively alleviate the impact of non-uniform cache access latency. By adopting migration alone without replication, the exclusiveness of cache blocks is maintained, thus further optimizing the cache miss rate. Simulation results using a full system simulator demonstrate that the proposed controlled migration scheme outperforms the shared caching strategy and compares favorably with previously proposed replication schemes.
inria-00446343 , version 1 (12-01-2010)
Mohammad Hammoud, Sangyeun Cho, Rami Melhem. ACM: An Efficient Approach for Managing Shared Caches in Chip Multiprocessors. HiPEAC 2009 - High Performance and Embedded Architectures and Compilers, Jan 2009, Paphos, Cyprus. ⟨10.1007/978-3-540-92990-1_26⟩. ⟨inria-00446343⟩
Collections
HIPEAC09
30 Consultations
0 Téléchargements
