HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Function Approximation based on Estimated Arithmetic Operators
Arnaud Tisserand 1
1 CAIRN - Energy Efficient Computing ArchItectures with Embedded Reconfigurable Resources
Inria Rennes – Bretagne Atlantique , IRISA-D3 - ARCHITECTURE
Abstract : This article reports preliminary results on hardware operators for function evaluation with moderate average accuracy. The obtained operators provide a small average error on the input domain but a few large errors may occur for some very infrequent arguments. The proposed approximation method combines two methods: i) approximation using low-degree polynomials with small and sparse coefficients; ii) operators for addition based on estimated arithmetic and integer power operators (x^2, x^3) with reduced accuracy. Typical delay reduction is about 20-50% and 15-30% for silicon area reduction compared to previous results.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00446527
Contributor : Arnaud Tisserand Connect in order to contact the contributor
Submitted on : Tuesday, January 12, 2010 - 6:34:59 PM
Last modification on : Wednesday, February 2, 2022 - 3:52:45 PM
Identifiers
  • HAL Id : inria-00446527, version 1
Citation
Arnaud Tisserand. Function Approximation based on Estimated Arithmetic Operators. 43th Asilomar Conference on Signals, Systems and Computers, Oct 2009, Pacific Grove, California, United States. ⟨inria-00446527⟩
Share
Metrics
Record views
103
